fuel pressure regulator
Old Aug 6, 2006 | 02:15 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
so it has been a few days since i took apart my intake and i can't remember where the vaccume line from the top of the fuel pressure regulator is supposed to go. can anyone help me out?
Old Aug 6, 2006 | 02:23 PM
daves12secV6's Avatar
it goes to the back of the tb on the top side i have a pic somewere lemme see if i can find it
edit nope cant find the pic,
Old Aug 6, 2006 | 02:38 PM
nm i found a pic
Old Aug 6, 2006 | 05:49 PM
Xophertony's Avatar
Axle/Gears: n/a
duh.... thanks man.
also does anyone know the tourqe spec for the lower_intake_pleum-to-Intake_manifold bolts? it is not in my service manual or chiltons manual. i also need the upperplenum-to-lowerplenum bolt spec, and fuelrail-to-lowerplenum tourqe spec.
these books leave you wanting for tourque specs somtimes. i guess if i can't find it i will just go with 25LBS. they are going into cast aluminum, so i don't want to make them too tight.
Old Aug 6, 2006 | 10:52 PM
ive ha dmine off about 5 times swaping injectors ive never tq'ed them,just went by feel since the bolts go into aluminum
Old Aug 21, 2006 | 12:44 AM
JoshDT91's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 2.8L V6
My 88 GM shop manual says 18ft lbs.
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
