Info on 4thgen 3.4 in 3rd gen.
Old Sep 8, 2006 | 09:59 PM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
ok how hard would it to be to swap the whole engine/wireharness/ecu into my car? my current engine is about shot so is the wireing harness. i understand that i will need to find a place to mount the ECU and all that but shurely it cant be that hard. i am planning on moving to the FWD heads at some point so if i can do this that would be one major problem out of the way.
Probably just a pipe dream but i am so pissed at my car right now that i am tempted to sell it to someone for the norust/never wrecked body. have had a few $1000-$2000 offers.
Old Sep 9, 2006 | 07:08 AM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
It's not hard but I suggest a slightly different approach.
Put in the 3.4 engine first with your old harness. Then replace your harness with another stock used harness for the same car.
It's a nice upgrade and a lot less headaches!
Good luck!
Old Sep 9, 2006 | 07:35 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Dale did that swap in show truck.
What I was planning w/the 3800 pcm was to put it in the a/c blower box (before it decided to break while being removed) since it was already there & the a/c didn't work anyway.
You'll also need to figure something out w/the tv cable, as teh 3.4 intake/tb mounting doesn't really have space for that routing.
Old Sep 9, 2006 | 12:51 PM
daves12secV6's Avatar
get the 3.4,and use the 3.1 sd computer,and swap the 3.1 intake onto the 3.4.
u also need to change the timming cover from the 2.8/3.1 onto the 3.4
Hotrodboba400
Dec 10, 2019 07:07 PM
camaro1185
Oct 26, 2015 06:51 AM
beltran89
Theoretical and Street Racing
46
Oct 7, 2015 07:36 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
