Gauge Question
Old Sep 11, 2006 | 10:59 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
Gauge Question
Basically, I pulled a V8 cluster out of the junkyard, and I cant use it because the tach will be off. Someone on these boards suggested that I swap the speedo. If I do this, my speedo will be accurate, right? I also want to swap out the oil pressure gauge so I have some numbers on it, this will read correctly as well right?
Thanks.
Old Sep 11, 2006 | 11:20 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
I have an 87/88 f-bird speedo from 3800 swap doing nothing, it should line right up if you need it ( for itty bitty fee ). should only take like a day to ship from dayton too
edit: yeah, shameless plug
Old Sep 11, 2006 | 11:34 PM
daves12secV6's Avatar
if u swap in the whole v8 cluster the tach will read 250 rpms low.not sure if u can just swap out the speedo part,never tried to seperat the gauges individually
Old Sep 22, 2006 | 02:21 AM
Drew's Avatar
All the guages bolt into the cluster individually and can be removed and installed individualy.
The speedometer is exactly the same regardless of engine. 120mph, 140mph, both will swap in and work accurately. Same goes for the volt gauge and gas gauge. The oil pressure guage will be different, because the V6 guage has a higher maximum pressure then the V8 guage. A V8 oil pressure guage might read accurately, but it will max out before the actual pressure reaches it's maximum. As already mentioned you'll want to keep your 6cyl tachometer since the V8 tach is calibrated differently and won't read correctly without modifying the circuitry.
ps: forgot to mention, your V6 tach has a higher redline then a V8 tach. Also, if you're just trying to get a oil pressure guage with numbers, most V6's with full instruments have the numbers printed on them, my 91 did.
Old Sep 25, 2006 | 07:14 PM
CC_HotRod's Avatar
Car: 1984 Camaro
Engine: V6
Transmission: 700 R4
Sending Unit
If I remember correctly when I switched from "idiot lights" to gauges I had to change the oil presure sending unit.
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
