Another oil pressure problem
Old Sep 17, 2006 | 03:24 PM
m390's Avatar
Car: 91 Firebird
Engine: 3.1 V6
OK fist i have a 91 firebird with the 3.1v6, when its idling its at 0 or something 10 or 15 pis then when im driving about 45-55mph its around 38-39 psi. I think the the sending unit or the gauge itself, but wanted or sugestions..
Old Sep 17, 2006 | 07:08 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
That pressure definitely seems a little low during idle, but with a load, you seem fine. Our stock gauges are notorious for giving false readings, but despite that, I would make it a point of replacing your stock oil pressure sensor first. Give the system a good flush while your at it, and fill it up with a full synthetic brand (preferrably Mobil One). If that didn't solve your problem, let us know...
Old Sep 17, 2006 | 09:56 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
You could also grab a cheap mechanical gauge and verify the stock sender's accuracy.
Old Sep 17, 2006 | 10:26 PM
m390's Avatar
Car: 91 Firebird
Engine: 3.1 V6
will do thanks alot...
89GTAOz
May 16, 2020 09:31 AM
db057
Aug 22, 2015 08:17 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
