TPI Cold Air intake work in V6?
Old Nov 9, 2006 | 06:38 PM
KBcobra's Avatar
Car: 92 Chevrolet Camaro RS
Engine: 3.1L V6
So do they work?
Old Nov 9, 2006 | 06:46 PM
daves12secV6's Avatar
yes they work on v6 camaros but not the firebirds
Old Nov 9, 2006 | 06:49 PM
Supermann's Avatar
Car: '86 Camaro, '85 Z28, '92 Firebird
Engine: LB8 2.8, LG4 5.0, LO3 5.0
Transmission: TH-700R4, T-5, TH-700R4
Axle/Gears: 3.42s, 3.23s, 2.73s
if you're refering to the one that came on stock tpi v8s from 85 to 89 (I think), then yes, and you'll find the same intake on any stock MPFI v6 from those years too. Its the best intake you can find for a 3rd gen camaro too.
If its some other aftermarket intake, it should work too, you'll just most likely need a small extension, but like I said, that stock one is the best you can get
Old Nov 9, 2006 | 09:28 PM
KBcobra's Avatar
Engine: 3.1L V6
cool guys thanks
Old Nov 9, 2006 | 09:59 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I've put one on my 91. If you search WAY WAY BACK, I did a typeup on how to put it in. Very simple.
1992 Trans Am
May 10, 2023 07:19 PM
Jake_92RS
Aug 11, 2015 10:39 AM
bryan623
Aug 10, 2015 11:33 AM
