Trying to remember what I need to pull tranny?
Old Nov 14, 2006 | 12:13 PM
87CamaroMan's Avatar
Car: Chevy Cobalt & Camaro
Engine: 2.2 DOHC/3.1
Transmission: Not so slushy slush box/Slush Box
Axle/Gears: Stock 3.23
Hello. Its been a few years since I had to change one if these. But here is my list that I can remember of what I need to pull a 700R4 from 3rd gen.
If memory serves me right all I need to pull a tranny out of these cars is 15mm (crossmember), 18mm (bellhousing), 10mm (Inspection cover) and 1/2" TQ (converter to flexplate) socked and wrench, 2 extentions one long and one short, a universal (swivle) adapter. Its been a few years since I had to pull one.
If I am missing anything or wrong, let me know.
Old Nov 14, 2006 | 02:47 PM
daves12secV6's Avatar
if i remeber right the tq converter to flexplate is also 15mm,and i think 2 of the bolts on the inspection cover are also 8 mm.
if u dont remove the tv cable from the throttle linkage/intake manifold (cant be done without removing the uper plenum) u also need a 12 or 13mm socket to get the trans pan off,and 10,or 8mm socket to get the tv cable unhooked form inside the trans.imho the easiest way is to unhook it from inside the trans,and just hook it to the new trans,be a good time to do a fluid/trans filter change in the new trans as well.if u do this and have access to a tig or mig welder this would be the perfect time to install a drain plug in the trans pan.makes life easier down the road if u ever need to service/or swap out the trans again
Old Nov 16, 2006 | 03:28 AM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
seems like youve coverd every thing, dont forget about the drive line u joint bolts, and inspect them real well or replace,
Are ya doing it with a tranny jack or by hand? i have profected the art of doing it by hand, lol, also there is the linkage and speedo i believe there is one bolt or just a clip thing, other then that make sure th tirq convert, sits back all the way on the trans,you godda hear that click,sometimes this can be mistakin, good luck be carfull and let us know how it goes,,
Oh yea and dont forget to inspect the flexplate for cracks ,,
be nice if you could do a pic by pic tutorial,, !
83 Crossfire TA
Jan 3, 2016 01:26 PM
GouldyGTR
Sep 7, 2015 09:05 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
Stryker412
Sep 7, 2015 09:11 AM
IROCZ1989
Sep 4, 2015 11:54 AM
