Fixed exhaust leaks. narrowed down fuel leak, sorta. o2 test?
Old Nov 24, 2006 | 05:20 PM
coolrimsatleast's Avatar
Car: 89 f-bird and some others
Engine: 3.4
Tightened header bolt, did flame test and it doesn't appear to be leaking. Moved clamp a little down on pipe and add another next to it. No more leaking there either.
Crimped fuel lines, both of them, and still lost fuel pressure. Pulled cold start injector (left it hooked to fuel line) and still saw no leaking while losing pressure. I might just order those accel injectors from summit.
Still don't know if I'm going inot closed loop. Don't know how to check.
Also how do I test the o2 voltage. I understand I should get fluctuating readings, etc, but I'm not sure where to hook up.
temp sensor is good I guess, as the temp is reading fine on the gauge. I'll take a peek into the maf and see if it's heating up like it should though.
Anyway gotta make a trip into town really quick and get something.
gta892000
Aug 11, 2019 11:16 AM
RedLeader289
May 28, 2019 01:47 PM
Elephantismo
Feb 13, 2019 12:51 AM
NZKnight
Oct 15, 2015 02:47 PM
Eric-86sc
Sep 28, 2015 11:37 AM
