headers in but ...
Old Nov 24, 2006 | 07:12 PM
puntank4200's Avatar
Car: '88 Camaro
Engine: v6-173-2.8L
Transmission: Automatic
headers in but ...
I just installed a set of pacesetters in my car but its sounds much worse. Before headers, I had a stock cat back with a 80 series flowmaster and the sound was sorta deep for a 6 but sounded good. Now with headers in, my car sounds horrible. It sounds like I have cut-outs, my car sounds very very raspy. Not to mention I lost a lot of low end power. I there anything I can do about the sound? Will a resonator help, or should I get a quieter muffler?
Old Nov 24, 2006 | 08:02 PM
daves12secV6's Avatar
instalkl a bullet muffle rin the intermediate pipe,it will help some.
Old Nov 24, 2006 | 09:54 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
odds are you have several leaks in the y-pipe, or even where they bolt to the heads.
Rather then using the "crush connections" they provide, have it welded.
Headers will loose a bit of low end torque, but gain top end.
Mine sounded deaper at idle, but up top it sounded more raspy.
Old Nov 25, 2006 | 08:49 AM
Car: '88 Camaro
Engine: v6-173-2.8L
Same here, sounds good at idle but raspy on the up end. I checked for leaks in the y-pipe and leaks around the heads but none as of yet. What will work better a dynomaxx bullet, flowmaster resonator or borlas resonator?
Old Nov 25, 2006 | 02:11 PM
turbo2825psi's Avatar
Car: 1992 RS Camaro
Engine: 5.0 tbi
Axle/Gears: stock 10 bolt 3.08's
ive got the dynomax sysem on my car no headers and its already really raspy at top end but ive got a test pipe on it i dont know if thats whats causing it but i can feal the power diffrance from stock
BumpaD82
Feb 26, 2016 02:57 PM
redformula88
Oct 14, 2015 06:08 PM
Chad Speier
Sep 24, 2015 12:32 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
