v-6 intake
Old Dec 31, 2006 | 06:08 PM
madman350714's Avatar
Car: 1989 CAMARO RS
Engine: V_6
v-6 intake
I want swap the 1989 mpfi to carb, is there another 2.8 intake that will fit from another make. I know i need the rest of the parts for the swap. I guess i have not found the right post if there is one. I am not worried about power, I just need the car to be reliable until i put a 350. Engine is good, just all those dam sensors and wiring is making the car unreliable
Old Dec 31, 2006 | 06:24 PM
Leo_padakin's Avatar
Car: 1985 reliant saloon
Engine: 2.2 pile of metal
Transmission: 3 on the tree
Axle/Gears: so tall theres no point
edelbrock?
Old Dec 31, 2006 | 08:03 PM
Car: 1989 CAMARO RS
Engine: V_6
thanks for the fast reply, but its only for "Chevrolet 2.8L V6
PERFORMER 2V 60° V6 (idle-5500 rpm)
Designed for 1982-85 2.8L 60° V6 Chevy"
unless you guys know it will fit?
i was thinking more along the lines used since there is no point to spending to much money on that 2.8
Old Dec 31, 2006 | 09:00 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
what about the s-10 intake? use a 2bb that'll fit.
Old Jan 1, 2007 | 01:58 AM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
Its the same Block & heads. well the heads are supposed to be a bit different but the intake will still bolt up the same. Not till the 3.4 did the blocks loose the carb mechanical fuel pump.
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
jerflash
Sep 24, 2015 03:11 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
