Cylinder head question
Old Jan 9, 2007 | 06:21 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
I started taking out the valves on my extra set of heads today. In the #4 cylinder(middle driver) exhaust port there is a hole going back to the intake. Just wondering what that hole is for.
Old Jan 9, 2007 | 06:44 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
old style vac EGR on s10's, and some of the other older cars that had this engine design.
Old Jan 9, 2007 | 09:21 PM
grimmcs's Avatar
Car: 91 Camaro
Did any Camaros have this design? I thought I heard that they changed head designs, but I though it was the size of the ports.
Old Jan 9, 2007 | 09:37 PM
firstfirebird's Avatar
Is it only on one head?
Old Jan 10, 2007 | 07:38 AM
grimmcs's Avatar
Car: 91 Camaro
Havent gotten to the other side. This one took me about 50 min just to get the 3 stuck valves out. I should have the others out tommorrow...Ill let you know.
Old Jan 10, 2007 | 10:09 AM
Dale's Avatar
Engine: 350 S-TPI
no, it will be on both sides. Left and right heads are the same casting, in fact same maching too.
grimmics, the carb heads have 1.6 and 1.3 valves, where FI heads have 1.72 and 1.42 valves.
that port is used on TBI s10 setups, I know that for a FACT.
Old Jan 10, 2007 | 10:49 AM
grimmcs's Avatar
Car: 91 Camaro
I bought these off of some guy on this site over a year ago. He said they came off a 3.1. So now I have some big paper weights .
Old Jan 10, 2007 | 12:33 PM
Dale's Avatar
Engine: 350 S-TPI
Why did you buy them? You have a 3.1, they should be the same as what you have unless they were modified.
Old Jan 10, 2007 | 12:39 PM
grimmcs's Avatar
Car: 91 Camaro
I bought them so I could have them P&P before I rip apart my engine, so I will have minimal down time. Plans changed and Im not going to use these anyways. So I was just going to clean them up in my spare time, and possibly sell them to someone who had plans like I had.
Old Jan 10, 2007 | 02:59 PM
Blue1989RS's Avatar
Car: 1989 RS
Engine: 3.1L + .060" overbore
Axle/Gears: 4.11, Auburn LSD
That hole is on every 60v6 with iron heads right? on the camaro V6 the intake gasket has a hole for it too, but the intake manifold itself only has a small indent that doesn't go anywhere. But like Dale said, it is only used for TBI setups. I think the carborated 60v6's have a tunnel that goes between both sides that heats the bottom of the manifold for faster warm up and to eliminate fuel puddling. Correct me if I'm wrong.
An no worries, I keep an extra set of heads in the garage, just in case.
fasteddi
Sep 2, 2015 10:29 AM
NinjaNife
Aug 23, 2015 11:49 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
