3.4 Heads with a 3.1
Old Jan 19, 2007 | 06:26 PM
BushyTea's Avatar
Car: 1990 Camaro
Engine: 3.1 V6
Hey,
I did some searching and I am sure the answer is out there maybe I just didn't search the right terms.
However, the 3.1 in my 90 camaro is freshly rebuilt for some reason the heads did not get worked over at the same time so a local shop says that is what is causing my engine to not run. The new engine with old heads is affecting that.
If that is true would it be worth just swapping some 3.4 heads onto the 3.1 or just getting my regular heads fixed?
I already know about an entire 3.4 swap. I saw the Tech article on this for the 2.8 so would that be the same for the 3.1?
Thanks,
Mike
Old Jan 19, 2007 | 07:22 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
RWD 3.1 and 3.4 heads are exactly the same. No added improvment. And yes, this has been discussed on here before.
Old Jan 19, 2007 | 07:23 PM
BushyTea's Avatar
Car: 1990 Camaro
Engine: 3.1 V6
Thanks, I figured it was just couldn't find it.
I am debating just doing the 3.4 swap if I can find a good deal on the motor.
Mike
Old Jan 19, 2007 | 07:28 PM
Dale's Avatar
Engine: 350 S-TPI
I'm hoping to bid on 2 cars in the next 4 days. If I get one, almost my whole car will be up for parts
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
92projectcamaro
Jan 18, 2016 08:00 AM
New2Chevy
Sep 28, 2015 12:35 AM
z28guy134
Sep 1, 2015 11:50 PM
