1989 V6 2.8L Firebird intake?
Car: 1989 Pontiac Firebird Mint. cond.
Engine: 2.8L V6
Transmission: factory
Axle/Gears: factory
hey im new to the threads jus looking for some intake help.
i was woundering if i could put:
1.cold air intake into my 89 firebird.
2.if a V6 3.4 cold air intake Kit would work on my 2.8?
3.if theres a thread on modding a 2.8L air box?
thanks pm for help or post up
i apreciate the help
Car: 1985 reliant saloon
Engine: 2.2 pile of metal
Transmission: 3 on the tree
Axle/Gears: so tall theres no point
SEARCH all of your questions. im amazed how everyone ask's the same questions. the chevy 2.8,3.1,3.4 are all the same. get rid of the 2.8, get a 3.1, add a i/h/e and then start searching all of your questions. almost everything has been talked about.
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
Hate to say this Noah, but that ain't cold air. The concept is great, but unless your air comes from in front of the radiator, your still at "warm/kinda cold" air.
Nothing wrong with that and it works great, but unfortunately it still isn't "honest-to-god", "According to Hoyle", Cold-Air-Induction. One of these days when my 89 isn't my daily driver I have plans to get the dremel out and get my cone to stick into the area under the pop-up headlights. Mine are permanently up and they are going to stay that way so I have a nice little cavity where the K&N could live just fine.
Mine is built about the same except I have a MAF car so right about where yours says Firebird Nation, I have the MAF with some rubber piping on either side, joined up to a 3" 90 degree PVC bend on the intake side, up to the rubber accordion deal. The other side of the MAF leads to some more plumbing and eventually into a K&N.
89_Kitt, most of us build them ourselves. PVC/Giant exhaust pipes/K&N Cone type filter, etc. Its a lot cheaper than paying way too much for something.
Its your car, you can do what you want to it. Click the sponsors on the main page of this site, specifically "Hawks" if you want to go with the "storebought" solution. Otherwise head to the hardware store and build one yourself for 1/4 the price. Theres nothing magic about it, you just want to get air from OUTSIDE the engine compartment, into your K&N Air filter, then into your intake, all the while maintaining as large a diameter pipe with as few turns as possible. PVC, rubber plumbing, brackets, big pipes, etc are your friends.
For your question #2 Kitt - have a look yourself and figure out if it'll work for you. Nobody here is going to do the work for you unless someone has done it themselves and they are feeling helpful. Its much faster to just look and see and try to see if it will work yourself, rather than be lazy about it.
And #3 - Look at the FAQ's and Tech articles, etc on the front page of this site. Quite a bit of info there. When I first build my "****-warm air intake" the first thing I did was delete the airbox and stick a generic (non-K&N cone type" filter on the end, just to see if it worked. It did and that gave me the inspiration to build one properly.
Car: 1992 Pontiac Firebird
Engine: 3.1
Axle/Gears: 3.42 Auburn Posi
Yes, but my only issue when building the intake was the smog canister being in the way. It's not an honest to goodness cold air intake, but it breaths about 90% better than the stock air cleaner hole that was the size of a quarter. Later down the line, if I manage to re-do it properly, I'll relocate the smog canister and have a K&N inside the actual fender, but I can't imagine much of a difference if at all from what I have now and that.
Car: 1989 Firebird
Engine: 2.8L V6
Axle/Gears: factory
thanks for the help
couple more questions
1. PVC version i heard "smells bad or melts?"From (the tech articles)
2. i saw some chrome fittings from kraggen (90* elbow, 6" pipe 3in diameter, would i be able to mount the MAF sensor to the end of the 6" pipe?and then run the conectoin to the cone?
(i havent removed my MAF i dont wanna break it unless i have all the stuff to do this mod)
thanks
thanks
Car: 1989 Firebird
1. I have a 3" PVC elbow on the end of my rubber accordion deal. It's been there for 5 years now. No melting, no smelling. Your mileage may vary.
2. THe trouble with the MAF sensor is that it isn't a standard 3 inch or any standard inch or metric opening. Thats why I used rubber plumbing on either side. You'll just have to find something that works.
It was, and still is. Stock Cold Air dual snorkels. Unfortunately only came with Camaro's. Won't just drop in a Firebird though, we have less hood clearance. Its about an inch too tall.
i thought the stock setup witht the dual air cleaners in fron of the radiator setup was suposed to be one of e best mthods?
Car: 1989 Firebird
https://www.thirdgen.org/forums/v6/6...-pvc-cold.html
Have a look at this one: He happens to have the exact same "rubber plumbing" that I was referring to.
Last edited by bobdole369; Jan 26, 2007 at 08:19 PM. Reason: Automerged Doublepost
Engine: 2.8L V6
Axle/Gears: factory
ok whats the best Conical K& N filter to buy without removing charcol canister to fit?
1.part number(s)
2.pic of the cone(if owned by you)
please and thank you
1.part number(s)
Allright so about the MAF and it's size and all...
a 3" silicon connector will slip over and attach a pipe to the 'exit' side of the MAF.
You need a 3.5" for the entrance. I just connected the filter straight onto my MAF. Got it at AutoZone for $20-ish. You can buy ones that come with reducers so you can put it on a 4", 3.5" or a 3" piping.
Here's a pic of mine..
I know you said you don't want to break the MAF unless you know you can/need to. The angled end of it is just glued on. It came off pretty easily for me with a flathead and some prying. I just used some JB Weld to put it back on at the angle I needed. I ended up not changing it much but it has to be perfect if you still have the smog canister and the your filter is a tight fit like you can see, mine was.
Altogether my setup in the picture was about $50. Much cheaper than a brandname intake.
Engine: 2.8L V6
Axle/Gears: factory
thats a nice set up
do you know the meassurements or does anyone know the meassurments of a good sized connical K & N cone filter?
i want K&N under my hood
Car: 1986 pontiac firebird
Engine: 2.8l v-6
Transmission: 5-speed
Axle/Gears: stock
Re: 1989 V6 2.8L Firebird intake?
i dont have anypics of mine right now but the filter is where the ac pump used to be and its a k&n 4x11 marine deisle filter housing and some random pipe i had in the garage it works great though
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
Yeah, he should have searched, but he didn't. Go ahead and let him know for next time that he should search, and then help him out.
Engine: 2.8L V6
Axle/Gears: factory
hey thanks man i finished my intake like 3 weeks ago lol
its jus been one thing after another. finished intake 3 weeks ago. left school got home hear noise from hatch pulldown, went to pick n pull and ripped one out of a hardtop camaro. then last week helped my friend with his second gen transam. 2 super 40 flowmasters[3in. in and 3in. out]+ headers+ 3 in. x pipe and exhaust- cat. = one loud @$$ 6.6L 403 oldsm. engine lol
[GA] Shorty headers
Night rider327
Sep 16, 2015 02:20 AM
