Who is the guy with the PVC cold air intake????
Old Nov 25, 2001 | 01:10 PM
Monkie's Avatar
You posted pictures a while back of your CAI and you drilled a hole in the piping to place your sensor. I wanna see the setup again.
Old Nov 26, 2001 | 08:43 AM
SAEspinz80's Avatar
that would be me....ironically i just posted them in another post, but here they are again.
made with 3" PVC
and using a little math, drilled a hole w/ 11/16" paddle bit, and the sensor screwed right in. the thread made a seal with the PVC
1990 Firebird 3.1
- Auto Trans, TA Body Kit
- Home Made C.A.I. (KNN-RE-0810)
- ASP Underdrive Pulleys
- MSD 8.5mm Superconducter Wires (custom-cut)
- MSD GM Blaster Coil (8226)
- AC Delco Cap & Rotor
- Bosh Platinum +4 plugs
- Mobil 1 Synthetic Fluids
- 2.5" Hooker Aero-Chamber Cat-back (27121)
- 2.5" Hooker Elite Stainless Extension Tips (31503)
- GTS Blackouts (stickers removed - #GT034)
- TB Bypass
KILLS = Dodge Daytona, 2000 Toyota 4 Runner 4WD,
1999ish Explorer XLT, "older" Jeep Cherokee, 68ish Mustang (died completely when the light went green )
LOSSES = 300zx (took me in 2nd )
"The racing dice added 5hp...I SWEAR!"
[This message has been edited by SAEspinz80 (edited November 26, 2001).]
Old Nov 26, 2001 | 11:11 AM
Monkie's Avatar
And I thank you.
Old Nov 26, 2001 | 04:46 PM
Black 86 'bird's Avatar
Car: 1986 Firebird, 2000 WS6
Engine: 2.8, LS1
Transmission: 700R4, T-56
Axle/Gears: Stock, Stock
What exactly does that sensor do? I may be putting on an induction setup myself friday!
2.8 mpfi
My only mod: Flowmaster 40 series
http://www.geocities.com/pita_j2000/MyFirebird.html?1002261961590
PICS ARE UP!!
Old Nov 26, 2001 | 05:34 PM
Monkie's Avatar
Tells your computer how hold or cold the air is and how much air there is
Old Nov 26, 2001 | 07:57 PM
Brian K's Avatar
http://www.geocities.com/overlift/Dcp02084.jpg
Old Nov 26, 2001 | 07:59 PM
Brian K's Avatar
Old Nov 26, 2001 | 08:19 PM
Monkie's Avatar
Yea I know Brian but I don't know what I would do with the charcoal canister that is in the way.
Old Nov 26, 2001 | 11:47 PM
Engine: 2.8, LS1
<font face="Verdana, Arial" size="2">Originally posted by Monkie:
Tells your computer how hold or cold the air is and how much air there is</font>
Thanks.. so it's kinda important...
2.8 mpfi
PICS ARE UP!!
Old Nov 27, 2001 | 04:57 AM
Brian K's Avatar
Battery is in the trunk.....
Old Nov 27, 2001 | 06:45 AM
Monkie's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Brian K:
</font>
You have to worry about a battery, I have to worry about a charcoal canister.
Old Nov 27, 2001 | 08:11 AM
427camaro's Avatar
Car: 05 Nissan Xterra
Engine: 4.0L DOHC
Transmission: 5 Speed Auto w/ OD
Where does the air get into the intake hose at? And what makes it cold air? Is the sensor already on the car and you just moved it? Can I rig my 2.8 like that?
2.8 Liter V6
No Current Mods
Third Generation Camaro Site
[This message has been edited by 427camaro (edited November 27, 2001).]
Old Nov 27, 2001 | 08:58 AM
syxx's Avatar
Monkie--If Brian's car is anything like mine the Charcoal canister is on the driver's side and not where the cold air setup is going. If I remember correctly, it is like mine, so he didn't have to worry about it.
427--The sensor is already there on your car, you can do that to you car as long at it is fuel injected. I know on Brian's car the air is drawn in from the fender. I think total cost is around 75 bucks with the filter, it may be less(but not including the battery relocation kit).
Syxx
89RS
Old Nov 27, 2001 | 09:18 AM
Brian K's Avatar
Around 50 bucks.. Not much is over that.. 30 for the filter and 5 for the PVC, the adapter was like 3 and the paint could have been a buck a can.. Can you mounthte canister upside down?
Old Nov 27, 2001 | 02:33 PM
Monkie's Avatar
<font face="Verdana, Arial" size="2">Originally posted by syxx:
</font>
Well if my car was like his I would also have it on the driver's side but since my car isnt like his mine is on the side with the air intake. And I kinda figured he didnt have to worry about it.
Brian, yea you can mount it upside down but the problem is where? I really dont even need it but it has sensors and I dont know if taking it out would mess something up.
Old Nov 27, 2001 | 03:08 PM
SAEspinz80's Avatar
427, what makes is "cold" air is that the air it is getting is as far away from then engine as possible, hence cooler....which is the whole point. its a huge upgrade over the stock setup, and yea ran about 55.00 including the filter. my next step, which is an idea i got fomr KED85 and TomP is that i am gonn enclose the conical so all the air come from underneath and not so much from the engine bay. i am not a big fan of gouging a hole in the fender wall, which i have seen pics of, so i wanted to leave it where it is. as cool as it can be w/o damaging the car and staying away from water!!
[This message has been edited by SAEspinz80 (edited November 27, 2001).]
Old Nov 28, 2001 | 10:56 AM
KED85's Avatar
Adjust your headlight housing, to be lower. Adjust the hood stop to be higher.
Try to create a slightly larger air opening right by the air filter, by moving those two areas.
When I saw the "air box" created outta plexiglass (so easy to shape, cut, etc) it was a great idea!
Thanks Graeme for making me visit Cruisers last Friday.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Nov 28, 2001 | 01:24 PM
SAEspinz80's Avatar
SWEET....nothen like a little team work huh?
when you saw the plexi-glass airbox was it cutout so the airfilter was covered on the top(hood-side), the right side(radiator-side) and back side(coolant tank-side), to in all it had three sides?? or was the top left open so that the air could get in and only covered on the right and back?? now that i think about it i thinki would probably only want to block the right and backside so i can avoid engine heat. if the top was covered then the air couldn't get in...unless it could sneak in from the front(nose-side). whatcha think. i think an airbox covered on the top, right and back would look bada$$, but think i would block air...
hopefully my description was good enough so you can decode what the he** i am saying.....lol
Old Nov 28, 2001 | 06:18 PM
KED85's Avatar
Let's make it real simple.
Go get cardboard box and make it.
Then make it outta plexiglass!!
You are 100% on the right trail.
NOW REMEMBER, the example I saw was a 1996 Impala.
Not our cars.
But it's wxactly like you think.
Make it from carboarad.
My hood opening is only like an extra 1/2 3/4".
Not really noticable at all. What I've done it take my air box lid, flatten it, NOT REMOVE IT, and I'm cutting away (not done yet, I gotta replace the fuel pump first!!) the underside hood bracing area to get more of a straight shot.
IT works better, tho just by opening the headlamp area more & flattening the box air lid. My filter is finally dirty!!
Chat Soon,
KED85
Karl
Old Nov 29, 2001 | 01:12 AM
91FIREBIRDGT's Avatar
Car: 1991 Firebird
Engine: 3.1LV6
Guys,
Once I can get a pic scanned of my intake, most of you might wanna try something similiar to it. I have a J-bent, 3 inch universal intake pipe connected to the TB. Then I have a intake that's for some 4cylinder car connected to the j-bent pipe. then at the end i have a K&N cone filter. It positions the filter the farthest I can put it. After I can cut a hole in the battery tray I can make it into a real COLD air intake and not just a cooler air intake.
1991 Pontiac Firebird V6 W68
Pioneer DEH-7000R, Pioneer 6X9 4way/4X6 2way speakers, MTX 250watt amp, MTX 400watt sub, custom intake, Flowmaster dual exhaust 80 series, PIAA HID headlamp conversions, custom tail lamps(regular F-bird but amber is now red), soon to have 16" Formula wheels.
Future Mods: Ram Air hood(98-up style), 4th gen style rear wing, custom Pearl white paint, 3.4L V6 engine swap, custom headers, the list never ends....
my webpage: www.geocities.com/lilsap23/SEANs_HOME_PAGE.html
Old Dec 7, 2001 | 11:25 PM
86BIRD-MY FIRST CAR's Avatar
Cant wait to see those puppies!
86 firebird 2.8
K&N replacement filter
modified air box
MSD ignitor
Hooker cat back
GNX style wheels
Old Dec 10, 2001 | 04:31 PM
88camaro's Avatar
i dont get how exactly is the air colder where the battery is then where the stock filters are, they are kinda at the most front part of the car, arn't they
Old Dec 10, 2001 | 08:36 PM
Car: 1991 Firebird
Engine: 3.1LV6
After I place my piping to go through the passenger side battery tray, and place the filter under the tray the filter will then be sealed away from any hot engine air and will be behind the right side signal lights. This will sort of give a ram air effect as well. BTW my car is a 91 Firebird so I have the different style nose, with the openings for the turn signals below the headlights. I still haven't made the 4" hole in that battery tray yet for the intake piping(haven't had enough time, too busy earning money to spend on my car )
Old Dec 10, 2001 | 08:43 PM
Monkie's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 91FIREBIRDGT:
</font>
Thats good and all but seriously did you think about water getting into it from when it rains?
Old Dec 11, 2001 | 10:48 PM
Car: 1991 Firebird
Engine: 3.1LV6
I've thought about that issue. And there's this company that works with cold air intakes and they make this thing that solves that problem. Also I live in sunny So. California, and in my area I really don't get that much rain. Also I can alway return my intake back to its short ram form.
1992 Trans Am
May 10, 2023 07:19 PM
kyle5647
Aug 15, 2015 11:56 PM
Jake_92RS
Aug 11, 2015 10:39 AM
bryan623
Aug 10, 2015 11:33 AM
