3rd Gen Ackermann Adjustment
Old Feb 2, 2007 | 02:43 PM
Blue1989RS's Avatar
Car: 1989 RS
Engine: 3.1L + .060" overbore
Axle/Gears: 4.11, Auburn LSD
Has anyone changed the steering box and idler mounting positions to change the ackermann angles at full lock? I'm prepared to change this to make my ligher nosed V6 3rd gen turn better for the upcoming autocross season.
In my opinion, this needs to change depending on weight and roll/suspension stiffness. I am more than unimpressed at how the front of the car does not hook when turning a sharp corner. I attribute this to the steering system designed to operate with the typical 3rd gen (SBC engine, small sway, weak springs, and daily driver).
If you have any information that would be great. If not, I will post what I find and do so that others may follow.
Old Feb 2, 2007 | 03:11 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
might want to try this in the suspension section.
hows the LT1 running?
Old Feb 2, 2007 | 05:52 PM
Blue1989RS's Avatar
Car: 1989 RS
I'll move it.
The lt1 screams! Pulls hard past 6k. It also has a Zexel Torsen with 3.07 rear.
Warlocksirix
Sep 3, 2015 12:26 PM
suzuki949
Aug 28, 2015 08:07 AM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
tricky1
Aug 23, 2015 01:17 PM
redmaroz
Aug 16, 2015 11:40 PM
