motor fan problem and e brake light
Old Feb 4, 2007 | 01:10 PM
kariya762's Avatar
My motor fan wont start after about 5 mins when the car is running. Then the check engine light comes on. My dad tried to install and new motor fan, but it still doesn't start. What do you guys suggest we try next?
My e brake light also turns on when the e brake is off. My dad also tried to fix this too. He pulled off the console so we could see what was going on. There's a plastic piece that is supposed to carry a connection to the dashboard and it's not working. My dad tried messing around with it and trying to open and close the plastic piece and nothing happens
I really need some help considering I'm going to be driving this car as my first car and haven't even gotten to drive it on the road "legally" with my temps.
Old Mar 14, 2007 | 03:31 PM
anika's Avatar
Car: 1988 RS
Engine: 2004 LS1
Transmission: 4l60e
if u still need it check if you have enough voltage to turn the fan motor on.
Old Mar 14, 2007 | 11:00 PM
tnt_viper's Avatar
Car: 89 Camaro RS, 99 Sunfire GT
Engine: 2.8L, 2.4L
your hand brake is probably stuck, does the light go off when you drive the car alot?
and check to see if you have voltage going to the fan and check to see if your connectors are good
Old Mar 23, 2007 | 01:28 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Re: motor fan problem and e brake light
In regards to the brake light,it is also on when you have a brake pressure problem. You might want to check the rear wheel cylinders for fluid leakage. An easy way to tell if this might be the case is to disconnect the sensor on the proportioning valve. Make sure the e-brake is off and the light should be off too. If its still on, the problem is the e-brake switch.
For the SES light, pull the codes and let us know what they are.
For the fan, connect A and B on the ALDL just like you're pulling codes, this will force the fan on and you can start checking the circuit for power and ground.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Omega
Aug 10, 2015 12:46 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
