2.8 not right
Old Feb 6, 2007 | 06:08 PM
adam86's Avatar
Car: 1989 GTA
Transmission: Stock 700r4
Axle/Gears: 3.08 POSI
2.8 not right
2.8 MPFI AUTOMATIC 150,XXX miles
hey guys i've been taking care of my 2.8 as much as i can since i've had it but the car just seems to get worse the more things i fix.
the idle seems unsmooth but doesnt change rpm more than 50 rpms and has a slight sputter to it.
after the engine warms up its runs just fine but idle is kinda shitty
a cold start take off makes engine hesitate very badly...
also there is a slight misfire everyonce in awhile
HORRIBLE GAS MILEAGE 10 MPG CITY & HWY
service done to car:
new timing chain
new water pump
new pvc
new fuel filter
new belts
new wheel bearings
new alternator
new battery
new MAF
rebuilt transmission
spark plugs
wires
distributor cap
rotor
vaccum lines
egr gasket
intake manifold gaskets
USED FWD injectors
USED ICM
USED coil(91 camaro 3.1)
USED TPS
USED IAT
cleaned IAC(not sure if good)
sea foam ran through engine
Last edited by adam86; Sep 4, 2007 at 10:32 PM. Reason: more stuff replaced same shitty idle
Old Feb 6, 2007 | 07:19 PM
Leo_padakin's Avatar
Car: 1985 reliant saloon
Engine: 2.2 pile of metal
Transmission: 3 on the tree
Axle/Gears: so tall theres no point
check your timing, and sounds like a vacumn leak. spray wd40 around where you think you might have one(throttle body area, with engine running) and if your idle changes, youve found your leak. my cat was clogged and it choked the engine really bad, and the car would seem to have to force itself to run. g/k.
Old Feb 6, 2007 | 08:35 PM
adam86's Avatar
Car: 1989 GTA
my timing was also done but i forgot to add that..
it was at 8degrees but i put it to 12degrees because i read somewhere that an older 2.8 would run better with the timing advanced alittle bit(small power increase from this)
Old Feb 6, 2007 | 08:40 PM
daves12secV6's Avatar
a valve adjustment should take car of the tap unless its a bad lifter.and if it hasent been done yet u are deff overdue for a new timming chain.
my niebors car has just over 100k on it and the timming chain has so much slack in it u can rotate the crank 1/4 inch in either direction before it will start to turn the cam.
if urs has enough slack it will deff lose power and gas milage,along with idle ruff
Old Feb 7, 2007 | 12:18 AM
adam86's Avatar
Car: 1989 GTA
the guy i got the car from said the heads were rebuilt at 100k.
the car sat for 8 years after the tranny & rear-end burned up... i've had the car running for almost a year now after repairing everything.
would a bad timing chain cause my mileage to be 10mpg?
what about the injectors?
Last edited by adam86; Sep 4, 2007 at 10:28 PM. Reason: CHAIN AND INJECTORS REPLACED
Old Feb 7, 2007 | 06:48 AM
firstfirebird's Avatar
Over time the injectors will clog up and spray an erratic pattern, not spray excessively.
Yes a bad chain will cause a problem because in essence you are "retarding" the cam timing by a few degrees.
The heads being rebuilt wouln't help a bad chain or bad lifter(s).
You could try having the injectors tested/cleaned because they are going to have to come off anyways to get to the route of your problem.
Are you getting any codes?
Old Feb 7, 2007 | 03:41 PM
adam86's Avatar
Car: 1989 GTA
there are no codes of any kind... im pretty sure all the sensors are working correctly.
when the car warms up this happens about once every 5 miles while im driving regularly...
Old Feb 8, 2007 | 01:34 PM
adam86's Avatar
Car: 1989 GTA
bump... any ideas?
the timing chain is my last resort due to the amount of work to change it...
Old Feb 8, 2007 | 05:18 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
whistling noise is definitly a vac leak. time to break out the carb cleaner to find it.
Old Feb 8, 2007 | 10:31 PM
adam86's Avatar
Car: 1989 GTA
a
Old Jun 22, 2007 | 08:53 PM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
Re: 2.8 not right
https://www.thirdgen.org/service-eng...ht-error-codes
54. Low voltage at fuel pump OR Low voltage at Fuel pump relay OR Output failure at quad driver module
Old Sep 4, 2007 | 10:31 PM
adam86's Avatar
Car: 1989 GTA
Re: 2.8 not right
im still having my idle problem and horrible mileage even after replacing almost everthing besides the engine.
could this be cause by my CTS(coolant sensor)? my fan turns on when it gets hot.. so does that mean its working?
Old Sep 6, 2007 | 02:52 PM
adam86's Avatar
Car: 1989 GTA
Re: 2.8 not right
im desperate to get this thing to run right!!! please help
Old Sep 6, 2007 | 04:16 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: 2.8 not right
As far as I know there is a seperate fan switch for the later 2.8 models.
The clt temp sensor would make a huge difference in gas mileage if it has failed. It will be adding warmup enrichment even when the engine is warm, making it run like crap. In addition, it would never go into closed loop.
To verify that your car is going into closed loop, short the ALDL diagnostic pins while the car is running. DO NOT SHORT THEM BEFOR YOU START THE CAR. shorting them while starting puts a surge through the ECM and it can be damaged. When you short the pins, watch the check engine light. It will be blinking. Do this with a cold engine, as it will be easier to see the difference when it occurs.
At first, the engine light should blink rapidly. This means the car is in open loop. (no oxygen sensor correction)
As the car warms, (about 160 degrees) the light should start to blink slowly. This means that the ECM is now in closed loop, and is using the oxygen sensor input.
Give it a go. If it never goes into closed loop, you found your problem.
Old Sep 6, 2007 | 04:52 PM
kuulkatdadieo's Avatar
Car: 1989 Pontiac GTA
Engine: 350 5.7 T.P.I.
Transmission: TH 700-R4
Re: 2.8 not right
Does this apply to 350's too?? If it does what terminals do you short?? Arn't these the far right terminals?? Can't you do this with a paperclip? How do you? Thanks
Old Sep 6, 2007 | 07:13 PM
Toehead's Avatar
Re: 2.8 not right
Yes, it does apply. I have never done it on a car with the later (not 160 baud) ECM's, but it should be the same.
You need to short the two terminals you use to flash the codes... only do it with the engine running. A paperclip should be fine.
Old Sep 6, 2007 | 07:27 PM
Re: 2.8 not right
These terminals are on the far right. Correct?
Old Sep 6, 2007 | 07:46 PM
Toehead's Avatar
Re: 2.8 not right
Yes. The two rightmost on the top row. Terminals A and B on this page
http://winaldl.joby.se/aldlcable.htm
Old Sep 7, 2007 | 05:10 PM
adam86's Avatar
Car: 1989 GTA
Re: 2.8 not right
i just tested it and the car went from open loop(fast blink) to closed loop(slow blink) within 5 minutes of driving...
the sensor itself looks pretty old and shitty but i suppose its working?
is there any other sensor that could cause my problem? when i replaced my TPS with a used one..
i didnt have the correct multi meter to adjust it so i just adjusted it tilll the check engine like disappeared.. i've drove the car with a very mis adjusted TPS and it runs pretty crappy
86maro_252
Oct 10, 2015 06:52 PM
usafirebird
Sep 29, 2015 11:58 PM
spartanreaper
Sep 25, 2015 07:22 PM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
89bird2.8
Sep 18, 2015 07:46 PM
