putting on the 2.8 headers
Old Feb 9, 2007 | 09:33 AM
pairtoe's Avatar
well i started my new exhaust today i only got one exhaust manifold off and already im screwed. i was going through and losening each bolt on the stock manifolds before completely removing them and the very last bolt i go to losen isnt there. at this point i pretty much new what happend the old bolt was probally all rust and brok off in the head from vibration. well 2 hours later when i get the manifold off i see im right. is there an easier way of taking the brok bolt out, or do i really got the take off the entire head???
and for any that wants to know the pacesetter headers line up and fit perfectly on an 87 camaro., no problems so far.
Old Feb 9, 2007 | 10:57 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Get a 90* drill and drill a hole in the center of the old bolt, then soak the hell out of it with Liquid wrench, PB Blaster, WD40 or whatever your preference on penetrating oil is, then EZ-out it.
Just make sure that you drill the hole straight and clean.
If you screw up, you'll have to drill it out to the next bigger size and heli-coil it.
Old Feb 9, 2007 | 05:04 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
the only problems we have seen w/ putting those headers on is the pipes lining up or hitting the oil pan, the headers themselves bolt up quite nicely, its down a lil farther that you may run into problems. one of the flanges on mine sits about .00000000007 (well not really) away from my oil pan. and if youre running the longer oil filter, you may not be able to anymore, unless they finally did modify the left side header to fit it.
Old Feb 9, 2007 | 05:25 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Mine fit perfectly. No clearence issues.
Old Feb 9, 2007 | 08:28 PM
coolrimsatleast's Avatar
Car: 89 f-bird and some others
Engine: 3.4
Mine was just touching the side if the oil filter. Few taps with the hammer gave it just under a 1/4 inch of clearance.
The section running under the front half of the oil pan was too long. I had to cut it, had a muffler shop spread one half a little, install into the car and then weld it.
I should have driven the 3.4 with the manifolds first, and then installed the headers so I'd know the gas mileage and power difference, but I didn't.
Old Feb 10, 2007 | 11:16 AM
pairtoe's Avatar
yeah there doesnt seem to be a problem with them fitting or clearance, but i have three bolts that were broke in the heads 2 on one side and 1 on the other. so now im stuck between a rock and a hard place as wheather or not to take the heads off or not. i think im going to have to but i really dont want to any sugestions there really isnt enough room to drill a hole and tap the bolts out.
Old Feb 10, 2007 | 12:34 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
You could soak the stuck bolts in PB blaster, than go at it with a vise-grip.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Wvcamaro
Sep 4, 2015 08:38 PM
InfinityShade
Aug 22, 2015 08:00 PM
theurge
Aug 21, 2015 12:46 PM
sreZ28
Aug 14, 2015 07:48 PM
