Hard Vacuum Lines
Old Feb 13, 2007 | 03:29 PM
pairtoe's Avatar
Hard Vacuum Lines
does any one have a hard vacuum line digram for a 2.8. or does any one know where i can get replacement hard vaccum lines, besides the junkyard.
Old Feb 13, 2007 | 05:16 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Karl (KED85) had posted pics of my 85 diagram, pretty sure your 87 IS different.
AZ/Advance Auto has the lines (skinny ones) in a semi-bulk pack, in the HELP section iirc.
Old Feb 13, 2007 | 05:24 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Go to a dealership. They will have a diagram and vaccum lines.
Old Sep 18, 2007 | 05:52 PM
Shookum2004's Avatar
Car: 1988 Camaro SC
Engine: 2.8v6
Transmission: 5spd manual
Re: Hard Vacuum Lines
So all the vacuum is one size fits all? i have the slightest clue how to replace these, and they seriously need replacing...
Old Sep 18, 2007 | 08:03 PM
oldschool's Avatar
Car: 1985 Pontiac Firebird
Engine: 2.8 LB8 HO
Transmission: 700R4 with OD
Axle/Gears: 10 bolt 7.625 open-factory 3.42
The vacume signal harness for the 2.8 third gen F-car is no longer available from the GM dealer. Go to the HELP section at advance auto buy the bulk lines and fabricate your own.
Old Sep 18, 2007 | 08:19 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Any of the parts stores will have everything that you will need to make a new vaccum system.
Old Sep 18, 2007 | 09:01 PM
micali's Avatar
Car: 1988 sport coupe
Engine: 2.8
Transmission: 700 r4
here you go this is for 86-89
http://www.autozone.com/az/cds/en_us...rInfoPages.htm This is the page that has all the years. I hope this helps.
I went to a salvage yard and found the lines off of a 3.1 and they worked. I had to make a few changes but over all they are fine. When I had to make a bend I used a lighter to heat the tube up and then cooled it off with cold water to harden it up fast. I even had to cut the hard lines and then I spliced them back with tubing and it works fine, no leaks.
Old Sep 21, 2007 | 10:00 PM
karrfirebird87's Avatar
Engine: 350 4 boltmain goodwrench crate
Transmission: 350 turbo 3 speed
Axle/Gears: i belive its a 323 gear ratio posi
HI IVE GOT ALL COMPLETE ORIGINAL, 2.8 V6 HARD VACUME LINES IN EXCELLENT SHAPE FROM AN 87 FIREBIRD YOU CAN HAVE THEM FOR 35 BUCKS INCLUDES S&H
LET ME KNOW IF INTERESTED
Old Sep 25, 2007 | 09:01 AM
forkvoid's Avatar
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
On the topic of hard vaccum lines: what's the point? Why not have all rubber and save yourself from the possibility of snapping them?
Old Sep 25, 2007 | 01:10 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
I think that the hard lines are a larger inner diameter. For a flexable one to be that but of diameter the rubber would be thicker so it doesn't buckle. Thats what I would think.
Todd84Z
Sep 4, 2015 08:02 AM
Jote4805
Aug 25, 2015 06:11 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
apie2546
Aug 10, 2015 05:43 PM
