questions , questions ??????
Old Mar 4, 2007 | 08:44 PM
tech1's Avatar
hey just wanted to know if any you guys have had this problem
when ever iset my secondary timing to 10 degrees . and shut car off and rehook brown/black stripe wire . crank car again and check timing again . i can give the car some throttle and the timing retards before it advances. is it supposed to do this . still having it pop througt throttle body like it is out of time . have new puter coming in two days . i checked fuses no problem . acts like about 2000 to 2500 rpm running out of fuel . any answers on where to look next . i have replaced dist and pickup , new wires and plugs , new front main seal new trans filter and trans fluid , new fuel filter new throttle body , new cap and rotor , the only thing left is puter and fuel reg and injectors. please help daughter going crazy wanting to drive . thank you in advance terry
Old Mar 4, 2007 | 09:33 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
have you checked the timing chain? ...to make sure it didn't jump a tooth somehow
Old Mar 4, 2007 | 10:09 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
I'm voting timing chain...
Old Mar 6, 2007 | 10:39 AM
tech1's Avatar
HEY GUYS THANK YOU FOR INFO NEW PUTER ON WAY AND NEW TIMING SET ON WAY BE IN TOMORROW. just going to replace both
Old Mar 11, 2007 | 08:09 PM
tech1's Avatar
put new puter in and timing set in .still spiting and sputering
Old Mar 11, 2007 | 08:42 PM
firstfirebird's Avatar
Have you checked compression? What car is it, MAF or MAP?
Old Mar 12, 2007 | 11:27 AM
tech1's Avatar
MAF replaced with new one .
Old Mar 13, 2007 | 05:40 PM
KrisW's Avatar
Engine: 2.8/TBI/TPI
Lots of members on this site (myself included) have also had a problem with ignition fire "bleeding off" because of the ignition coil.
The last time I had this problem (backfiring, sputtering, and other weirdness) I didn't find the problem until it was night. When it is dark, you can see the craziness if there is an iginition thing going on under the hood that you can't see in the light...
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
