87 firebird
Old Mar 5, 2007 | 10:22 PM
stonegargoyle's Avatar
87 firebird
my ride wont run. when sprayed with ether/starting fluid will start but with no revving ability,can hear electronic fuel pump come on. is there any other pump between fuel tank and throttle bottle? 87 2.8 6 cyl, auto,firebird,256,000
Old Mar 5, 2007 | 10:40 PM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
how long has it been sitting? do you have any codes? try to start, if it idles for a sec, does the SES light come on?
There is a fuel filter between the pump and the engine... it is under the driverside lower crossmember (under car, between driver door and the driver rear wheel). I have also seen one in the engine bay on some carb vehicles. look at your chilton or haynes manuals.
if it has been sitting for a long time, may be bad gas. gas degrades after 6 months or so. Your carb or FI may be clogged. rebuild carb or clean injectors. Please give us as much information as possible. a fuel filter is only $7-15. your's may be a pain to replace due to rust and crap building up (dirt) around your filter... but have patience.
Old Mar 11, 2007 | 04:16 PM
my ride
it wasnt setting at all.
i got fuel on the way home from work, then later that evening i took my son to work and in the morning it started for a minute maybe and stalled then would not start since. Today i assured fuel through the filter, wasnt that bad to loosen, then assured fuel at the fuel line to the injector set up one line had fuel the other was dry with a fuel smell.
i then did a pin test where it should give a 12 sequence flash and it flashed once and then ses light came back on permanently. this with the igniton in the on position but not engaging the starter.
<a href="http://photobucket.com" target="_blank"><img src="http://i102.photobucket.com/albums/m...5/IMG_0011.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
Old Mar 11, 2007 | 06:51 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Does your vehicle have a MAF or even run an air filter? I hope s due to the above pic.
Old Mar 11, 2007 | 09:58 PM
MAF?
what is an MAF? i have this piece i removed.
Old Mar 11, 2007 | 11:29 PM
boostedv6's Avatar
MAF stands for mass airflow sensor. It's a black cylinder with a connector on the side that goes in front of your intake manifold. Without it the car will not run. You might also need your intake air temp sensor which screws into the Y-shaped part of the intake(the part right above the filters).
64goatman
Sep 9, 2015 01:09 PM
jtwoods4
Sep 3, 2015 05:39 PM
Formula_88AE
Sep 3, 2015 01:47 PM
jtwoods4
Sep 3, 2015 10:19 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
