S10 heads
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
They will bolt up, but the carb heads have smaller valves then your fuel injected heads. So I would NOT use them.
I have a spare set of heads if you need. PM me if you need them.
Transmission: 5-speed/T-5
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
GM says that the mpfi head or "fuel injection head" from S-trucks or F-bodies (even mpfi fieros) are the best stock head to run. Better cooling passages as well...
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
