Need help with rusted leaking fuel lines
Car: Chevy Cobalt & Camaro
Engine: 2.2 DOHC/3.1
Transmission: Not so slushy slush box/Slush Box
Axle/Gears: Stock 3.23
Hello. I just got my Camaro Towed up to my new house yesterday and I started working on it today. I just got it the car. It had less than a 1/4 tank of gas in it, well it wasn't really gas is was alot of water and dry gas. It smelled like Vodka when I started to drain as much as I could out. I filled is up with some fresh gas did a very basic tune up (plugs, wires, cap, and rotor) Well it wouldn't try to start. I changed the fuel pump relay on it because I was buzzing/clicking a couple of weeks ago and now it does nothing. Well I pulled a plug out and it was still dry. So I went to check my filter and the lines where pretty rusty. Well when I tryed to loosen the one bolt and the line from the tank to the filter sprung a leak. It took me, my dad and a guy I work with forever to get the line clamped down. It seems that I am going to have to change the fuel pump and all of the lines. One of my questions is if anyone has a pic or a legable drawing of where I can cut in my trunk to get to the fuel pump. I really don't want to drop the rear. I don't care about cutting a hole in my car is has enough in the floor as it is. And how hard would it be to replace the lines with this http://store.summitracing.com/partde...&view=1&N=700+ . And are thoes other 2 lines with the fuel lines my rear brake lines. I should change thoes also they are just as bad as the fuel lines.
Thanks in advance.
Thanks in advance.
Car: 1989 GTA
Transmission: Stock 700r4
Axle/Gears: 3.08 POSI
Re: Need help with rusted leaking fuel lines
heres a link to the cutout of the sheet metal to get to the fuel pump..
https://www.thirdgen.org/forums/tpi/...cces-done.html
and for the metal fuel lines.. you will probably have to go to the junkyard and find a camaro or goto the dealership and see if they still have them.
I have been researching the rear main brake line for my 83 bird and going through some older posts I found this link.
http://finelinesinc.com/
They have pre-bent brake AND fuel lines.
dzimmerm
dzimmerm
dzimmerm
dzimmerm
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
theshackle
Mar 5, 2017 06:37 PM
AkDrifted
Aug 17, 2015 07:45 PM
