Different Direction
Old Mar 25, 2007 | 05:55 PM
Kamorov's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: L98 TPI 5.7L
Transmission: Stock ... For now
Axle/Gears: Borg-Warner 9-Bolt
Different Direction
This weekend on my way back home from Daytona something went very very wrong with my engine. That has placed my Turbo 3.1 project on a very very long hold. Luckilly a friend of mine with a Buick Regal T-Type is redoing his engine and decided to sell the whole motor to me. With a few key parts missing, like the computer, wiring harness, and exhaust manifolds. Now my problem is that I do not know if the Turbo 3.8 will drop straight into a 91 Camaro. If anyone knows please let me know. Cause I need to go ahead and get what is needed.
If there was a thread about this already please show me the way cause I couldnt find it...
Old Mar 25, 2007 | 06:01 PM
daves12secV6's Avatar
Re: Different Direction
the ex manifolds are the hard part they are discontinued,did u get the turbo with it?im sure somone makes the headers aftermarket for them for swaping them into f-bodys u just have to look around
i reaserched the swap along time ago and cant remeber all what is needed,to do it, but since u dont have a computer.harness id say go with a megaquirt unit its prolly cheaper and its tunable via a laptop.
Old Mar 25, 2007 | 06:11 PM
DemonKnightDK's Avatar
Car: 1985 Firebird
Engine: 3.1L (planning for a turbo)
I know you can use the heads from a FWD lesabre, so maybe those manifolds work too?
Old Mar 25, 2007 | 06:14 PM
Kamorov's Avatar
yes I have the turbo it was the turbo that was originally going on the 3.1... and I was actually looking at the MegaSquirt II mainly cause it has all those nice lil features ... my main concern was the motor mounts
Old Mar 25, 2007 | 06:16 PM
motor mounts u can buy still id talk to one of the tta guys and see exactly what u need.or try the engine swap board many ppl there have done the swap
Old Mar 26, 2007 | 12:02 AM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
You also need either a 2004R transmission with a Buick (B-O-P) bellhousing to bolt to your engine or a 700R4 from a V8 car or truck.
If you get the 700R4 then you need to take your tailshaft housing off of your V6 tranny and fit it to your new V8 tranny so that you can bolt on your torque arm mount. Your V6 uses the "metric" GM transmission bolt pattern and your Buick V6 uses the old (B-O-P) bolt pattern for the transmission.
If you get the 2004R transmission then you have to either fabricate a torque arm mount to fit your transmission crossmember (after you modify it to bolt up to your tranny) or you can buy a ready to go crossmember from Spohn.
Your motor bounts use special lower halves that are solid and bolt to the frame while using normal rubber upper Buick mounts that bolt to the block. You can make the lowers if you take a little time with a small sized home use mig welder to fab the lowers and then take them to a welding shop to finish them up...
Good luck on your awesome new swap!!!
The best stock heads to run on your motor will be from a Lesabre, Bonneville, or Delta 88/98 with a 3800 vin code C from 1988 through 1991. Don't use the vin code L engine heads because the intake ports don't line up. The vin code 3 heads don't seem to make the same power in stock form...
Old Mar 26, 2007 | 05:34 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
there is an article in FAQ on how to do thsi swap, step by step, it even gives you part numbers of the stuff still available.
https://www.thirdgen.org/buick-3.8L-...ne-swap-f-body
Old Mar 26, 2007 | 03:05 PM
Kamorov's Avatar
Big thanks everyone ... as soon as I get it going (as soon as I get the damn money) i'll keep yall updated with pics and then time slips.
oh and this 3.8 is fully built already running 12s in a Regal T-Type ... imagine in a lightened 3rd gen
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
gixxer92
May 18, 2017 11:20 AM
efiguy
Sep 27, 2015 01:30 PM
Lmancha96
Sep 25, 2015 08:11 PM
