i wanted to say thx to all the members
Old Mar 25, 2007 | 06:02 PM
JohnSjr's Avatar
some before and afters ... some are just ... wtf..
1988 sc 2.8
before
after
before
after
before and after .....
and this is the pile of junk removed so far ...
i would like to thanks to our members that gave me the info on taillight modding and refinishing.
also... i wanna thank TPI-Hearse for his assistance in the body part replacements i needed.
now... back to the grindstone till next weekend.
Old Mar 27, 2007 | 08:06 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
Re: i wanted to say thx to all the members
Looks nice so far. Keep posting updates!
Old Mar 27, 2007 | 08:10 PM
noahTHEpurdy's Avatar
Car: 1992 Pontiac Firebird
Engine: 3.1
Axle/Gears: 3.42 Auburn Posi
Great work so far!!!
Old Mar 31, 2007 | 07:26 PM
JohnSjr's Avatar
well the bumper reinforcements back on and same with the air assembly ( set in place so i could snap the updated pic )
all courtesy of my bud, tpihearse. ( looks different doesn't it ) lol
Old Apr 7, 2007 | 08:48 PM
JohnSjr's Avatar
a lil more progress.
thanks to mother nature.
Old Apr 8, 2007 | 04:49 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
looks good
that engine bay/under hood color is fugly, and that's coming from someone who liked the color of their yellow/beige bird.
Old Apr 8, 2007 | 08:25 AM
JohnSjr's Avatar
work in progress... the hoods gettin yanked and replaced due to a curl in the front lip and a bend in the back passenger area from the accident. ( hinges are bent too because it still doesnt close fully)
engine bay... thats a project i have to work on still... i just wanted to get the car back on the road and continue from there.
Old Apr 8, 2007 | 12:45 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I must have missed something, but can you link to the thread or give me a quick how-to about the taillights? Those look fantastic!
Also, the air intake pipe, how did you clean that up so nice as well?
Old Apr 8, 2007 | 01:30 PM
JohnSjr's Avatar
Green scrubby to remove main issues.
1500 wetsanded till its smooth but still slightly scratched.
wiped down with alcohol.. air dried and then taped off what i didn't want to be black.
sprayed the black and while it was still wet i removed the tape and sprayed the hi-gloss clear.
ALL LENSES PLACED FACE UP SO THEY REMAIN FLAT ( AVOIDS ANY RUNS )
placed in a heated room where the temperature was 75F and no dust to dry.
(all pics are after overnight drying.)
1 green scrubby ( use wet and use lightly to remove main body of discoloration and chips )
1500 grit wetsanding paper ( lightly yet again to achieve desired look )
1 can bumpertrim black. ( 2 coats )
1 can hi-gloss clear ( 2-3 coats )
1 roll 2" painters blue tape ( easier to remove )
rubbing alcohol ( to remove any possible grease remaining )
rubber gloves
i recommend waxing lightly before you install that way you dont scratch them later on.
work time: about 35 minutes per lense to get comfortable look and feel
dry time: overnight
do the same process for the air cleaner assembly.
hope that helps.
Old Apr 9, 2007 | 02:23 PM
Sonix's Avatar
Car: 1982 Trans-Am
Sure does, thanks! I didn't know it was only a scotch brite and wet sanding. I figured there was polishing involved... Well, I guess it couldn't hurt to add that in as well. Bumper trim black paint eh? I'll remember that, thanks.
customblackbird
Aug 15, 2021 10:16 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
Linson
Aug 21, 2015 02:12 PM
THX181
Aug 6, 2015 10:21 AM
