Modifying Headers.
Old Mar 30, 2007 | 10:10 PM
noahTHEpurdy's Avatar
Car: 1992 Pontiac Firebird
Engine: 3.1
Axle/Gears: 3.42 Auburn Posi
Modifying Headers.
What modifications need to be done to the Pacesetter headers to be completely compatible with the 3.1? Where would I need to get bungs welded in, etc.
Thanks in advanced!
Old Mar 30, 2007 | 10:52 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
Re: Modifying Headers.
Depends on where you live and if you have inspections on your car or not. They will bolt on the 3.1 (which I assume you already know). Even if you modify them to hook up the AIR system, they still won't be legal if they check the carb number on the headers. If they don't check, you can look to see where the AIR tubes hook up on your manifolds and put bungs on the headers in those locations or you could ditch the whole smog system.
Old Mar 31, 2007 | 05:55 PM
1988CamaroSC's Avatar
Car: 92 Camaro RS
Engine: 5.0L
Transmission: AUTO, 56k orig
ditch the smog system!
Old Mar 31, 2007 | 09:17 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Transmission: Automatic
When i installed these on my 1992 camaro 3.1. I had to take off every tube on the smog pump to get enough room for the passenger side header. I have the smog pump still on the car and being turned by the belt. Also i would suggest removing the studs in the head, they wont keep the headers tight enough and they will blow gaskets every two days. My friend is about to get his pa inspection liscense, so i wont have a problem getting it passed.
Old Mar 31, 2007 | 09:29 PM
Engine: 3.1
Man, I wish I knew someone about to get his PA inspection license, lol.
Old Mar 31, 2007 | 09:54 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
yeah i had a shot at getting my liscense but missed one to many questions. Suppose to have 9 hours off class. Well our teacher gave us about 2..lol
Old Apr 1, 2007 | 10:27 AM
badpontiac's Avatar
Car: 1986 pontiac firebird
Engine: 2.8l v-6
Transmission: 5-speed
Axle/Gears: stock
i dont have any smog stuff on my car but it looks like its there and working most parts of pa is visual only it dont have to work but its gotta be there i almost had my license but my teacher never sent in my test to get it cause i was the only one in my class old enough to get it at the time so now i have to wait till my jab will pay for me to go
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
NZKnight
Oct 15, 2015 02:47 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
