odd idle
Old Mar 30, 2007 | 10:47 PM
rover420's Avatar
Car: 88 camaro
Engine: 3.4
Transmission: t-5
Axle/Gears: limited slip posi 3.42
odd idle
well i did the old 3.4 swap had some gas problems and dozens more finally got it all good and smooth only thing is that she wants to idle at 1200 rpm which is fairly high.
I got 13 inches of vacuum.
The book says i only need 10 so i geuss that's alright.
When i let off the gas it bogs and almost sounds like it's going to stall, but it sits at idle.
I'm pulling a code 34 or whatever code it is (might be 43) for a MAF sensor but i'm thinking it's in the circuit itself i don't really think a MAF sensor can just crap out like that but i could be wrong. It also sounds like it's lacking power. I'm thinking that since my MAF it is out it's going into a limp home mode because it has no clue how much gas to mix in with the air or vice versa.
Me my brothers and my cousin are all stumped on this one i should of just stuck a carb on it then i probably wouldn't have so many problems.
Old Mar 30, 2007 | 11:01 PM
pepper6181's Avatar
Car: 91 Camaro RS
Engine: 3.1L
Re: odd idle
somebody correct me if I'm wrong but I think that's low manifold vacuum....I get a steady 22 inches on my 3.1. Were are taking the vacuum reading at?
Old Mar 30, 2007 | 11:04 PM
rover420's Avatar
Car: 88 camaro
Engine: 3.4
Transmission: t-5
Re: odd idle
i checked it right where the vacuum ball usually hooks up at the T on the upper plenium.
Old Mar 31, 2007 | 04:03 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Re: odd idle
yeah, that's a low reading, nust be a misprint in the book.
you should have right around 18" of vacuum at idle. With a low vacuum reading, the ECM will think that you're under a load and add fuel, raising the idle. A small vacuum leak will do this to you, so I suggest you get a can of carb cleaner and spray away.
Find the source of the leak and you'll fix the high idle problem.
Old Apr 1, 2007 | 10:22 AM
rover420's Avatar
Car: 88 camaro
Engine: 3.4
Transmission: t-5
Re: odd idle
alright cool i'll do that. If u spray carb cleaner into a vacuum leak it will raise ur idle so u know where it would be right. Also is there supossed to be a inline fuse for the MAF circuit?
86IROC112
Nov 27, 2015 09:54 AM
IROCtometal
Sep 20, 2015 11:08 PM
Stryker412
Sep 20, 2015 06:59 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
