2.8 Refuses to run at random times!
Old Apr 4, 2007 | 09:32 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Hey, I just got my car on the road last week. The first time I ever took it out (First time driving a 5 speed) The engine failed while I was coasting in neutral. Which resulted in NO power steering, and NO power brakes. I think it's the fuel filter getting clogged up, so I'm going to change it tommorow.
But this is getting out of hand, It ran fine until last week. It could be bad gas, so I topped it off with some 91 Octane, and some Fuel Injector cleaner (Which usually never works anyway). What else could it be? Injectors?
Old Apr 4, 2007 | 09:36 PM
daves12secV6's Avatar
Re: 2.8 Refuses to run at random times!
i woudl check fuel filter,fp relay/pump and also the ign moudle.
also check the fuses for the ecm etc.
did it throw any codes?
Old Apr 4, 2007 | 11:09 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
It could be a lot of things, but we need more information?
Did you have any electrical power? Did you try to restart it by letting the clutch out? If so, did it show an RPM signal on the tach?
Did it sputter then die. or did it just shut off?
What work has been done recently to it?
Did it start immediatly when you tried?
There are still a lot of variables that need to be addressed
Ghettobird52
Jul 5, 2024 11:18 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
fonzie85
Aug 13, 2015 11:50 AM
86Base
Aug 8, 2015 01:34 PM
Sherpajames
Aug 7, 2015 06:56 PM
