gonne be parting out the 89 soon
Old Apr 11, 2007 | 05:08 PM
daves12secV6's Avatar
hey guys i figured id see if any of u guys need any parts off my car.
my deal for the iroc fell threw, so i will be gutting my current rs for my alky injected drag car build.
im gutting the interior
145 mph cluster
seats
trim pieces
dash pad
dashboard
seatbelts
console
power trunk pull down and all trunk pieces
door panels
arm rests
+ more i cant think of atm
from the exterior
16" iroc rims
front 1le hollow sway bar
custom wonderbar
quick ratio steering box
custom adjustable 2 pt stb
iner fender plastic
brand new master cyl with 4 wheel disk prop valve
from the engine compartment
302 ecm 2.8/auto
complete wiring harness for engine
complete interior harness
heater box
brand new billet strut mounts
and last but not least
my current set of turbo pipes
custom under k member y pipe t3 flanged has flange for 2 bolt wastegate
5 bolt flanged downpipe
edit + brand new modine v6 radiator
ill take offers on everything, but i prolly wont be starting to gut the car for about 1-2 weeks
Old Apr 11, 2007 | 05:13 PM
firstfirebird's Avatar
Re: gonne be parting out the 89 soon
What color is the interior and how's the drivers side pillar?
Old Apr 11, 2007 | 05:16 PM
inetrior is black and grey
drivers side pillar has a hole in it were i put a screw in to hold my tri gauge pod since the tape the supplied with it was crap
Old Apr 11, 2007 | 05:18 PM
LMAO, that is the same reason I asked!
Old Apr 11, 2007 | 05:22 PM
im also looking for fiberglass rear deck
fiberglass doors
and aluminum rear brake drums
Old Apr 11, 2007 | 05:27 PM
The drums will make a big difference, isn't the formula: 1lb of unsprung weight = 10lbs of sprung weight?
Old Apr 11, 2007 | 05:29 PM
im unsure of the top of my head, if i cant get a set of aluminum drums im going to see if i can machine the hell out of mine
Old Apr 11, 2007 | 06:23 PM
boostedv6's Avatar
How much do you want for the seats shipped to 85296? Do you have any pics of them? if you do could you send some to kslocum@email.arizona.edu. Thanks
Old Apr 11, 2007 | 07:03 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Is the interior trim black? If it is black Ill take it, if it isnt already taken. Also do you have any pics of the wonderbar? Interested in that also.
Old Apr 11, 2007 | 07:53 PM
shipping the seats out to az will cost alot,ur prolly better off getting some at a local boneyard,though when i get a chance i will measure them and see how much one wieghs so i can get a shipping qoute
what trim pieces do u need,yes its black (some pices are bad though
the wonder bar i dont have pics for,its a modified stock wonderbar
the stock bar has thin wall tubing inbetween the flanges, i cut out the thin wall tubing and welded solid bar stock in its place
Last edited by daves12secV6; Apr 11, 2007 at 07:55 PM. Reason: Automerged Doublepost
Old Apr 11, 2007 | 08:51 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
not needing but possibly interested in the billet strut mounts. how much are you looking to get out of them?
Old Apr 11, 2007 | 08:55 PM
180$'s
Old Apr 11, 2007 | 08:57 PM
Car: 91 Camaro
ok, since I don't really need them, I should probably pass them up.
Old Apr 11, 2007 | 09:58 PM
transamrob86's Avatar
Car: 1986 Firebird
Engine: 2.8
Axle/Gears: 3.42s
how much for the turbo pipes? and if i buy that set up is that basically all i need to run a turbo pipe wise?
Old Apr 11, 2007 | 10:06 PM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
how much for:
i dont need the interior.. just trunk pull down/up motor, and the bracket to bolt it on.
Old Apr 11, 2007 | 10:33 PM
boostedv6's Avatar
[quote=daves12secV6;3300489]shipping the seats out to az will cost alot,ur prolly better off getting some at a local boneyard,though when i get a chance i will measure them and see how much one wieghs so i can get a shipping qoute
Nevermind, I found a pair of seats.
Old Apr 12, 2007 | 10:32 AM
grimmcs's Avatar
Car: 91 Camaro
The trim peices that go around the floor of the car(kick panels/door sills/etc.). I have gray right now and want to go to black. Which peices are bad?
Old Apr 12, 2007 | 10:40 AM
200+ shipping on the pipes its only the hot pipes, u would still have to make ur own intercooler pipes, if i decide to redo my intercooler and pipes i can include those for another 200$'s(inetrcooler, pipes and bov) then all u will need to buy is the turbo/wastegate and oil lines
driver side sill has a crack in the back,and i believe the carpet is starting to peel from the passenger side kick panel, ill have to get pics for u
btw the door panels are black and grey not solid black i think i have pics of the stuff in my photobucket when i have time t onight when i get out of work ill take a look
scottie trunk motor is pending ill get back to u if it falls threw
Old Apr 12, 2007 | 12:50 PM
Car: 1986 Firebird
Engine: 2.8
Axle/Gears: 3.42s
for the extra 200 after would that include the pipes and the intercooler etc or just the pipe. cuz i would really really really be interested if it included all the stuff cuz thats one of my biggest problems with a turbo project, i dont have the fab skills.
Old Apr 12, 2007 | 01:25 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
If ya end up swaping fans or running better id needs one off a 6 or 8. Just really need the plastic parts. The motors unbolts / screws, when ya go to buy a new one thats all they hand ya is a motor.
N E way motor can be removed to save weight if ya end up with extra one.
could alsp swap on powder coating if you wish.
Have done that before here for a few folks.
Old Apr 13, 2007 | 04:10 PM
Car: 1986 Firebird
Engine: 2.8
Axle/Gears: 3.42s
actually Dave what are you going to do with the 2.8/3.1 whatever it is in your car now?
Old Apr 13, 2007 | 04:34 PM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
my camaro was broken into and my console was broken badly , how much would ya wanna sell me it for ?
and how much for the driver side female belt front ?
Old Apr 15, 2007 | 04:39 PM
Car: 1986 Firebird
Engine: 2.8
Axle/Gears: 3.42s
you still partin the car out?
Old Apr 15, 2007 | 04:43 PM
sorry guys been a lil busy,yeah i am but its not gonna be for another week or 2
the motor in the car im saving as a spare block
and yes for the extra 200 ill throw in the intercooler and stuff
Old Apr 15, 2007 | 04:56 PM
Car: 1986 Firebird
Engine: 2.8
Axle/Gears: 3.42s
Its ok. I didnt mean to get up your *** about it I am just really anxious to get this thing back on the road again and with most of the custom fab stuff done it makes it alot easier on me. And the time thing works out great as I only have two weeks of classes then a week of finals then I am home for the summer. JW, How much modification do you think I will need to do to fit an 86 bird?
Old Apr 15, 2007 | 04:58 PM
what side is ur battery on ? driverside or passenger side, ohh a bird id have to make sure the intercooler i have will fit behind the grill
Old Apr 15, 2007 | 05:11 PM
Car: 1986 Firebird
Engine: 2.8
Axle/Gears: 3.42s
battery is on the drivers side.....
Old Apr 16, 2007 | 06:04 PM
Car: 1986 Firebird
Engine: 2.8
Axle/Gears: 3.42s
Dave I see in your sticky that your battery is on the other side. That would be just a simple battery relocation. Any news on fitting the intercooler to a firebird? My front air dam is long gone so if a custom one is needed then that should be no problem.
Old Apr 16, 2007 | 06:44 PM
yeah u can relocate the battery, u need a passenger side batt tray/holddown, and the right 12+ side cable.no i have to get over to my friends house and actually measure the area behing the nose of the firebird to be sure.right now nj is kinda under water lol, we got 10 inches of rain in the last day,so i havent gone anywere
Old Apr 16, 2007 | 06:56 PM
Car: 1986 Firebird
Engine: 2.8
Axle/Gears: 3.42s
yeah I was watching on the news and saw all that rain. didnt know it was you tho. that stinks.
Old Apr 16, 2007 | 07:23 PM
yeah i live right next to a river as well, there is one maiin street when u get out of my apt complex well a 1/4 mile in either direction is under about 6 ft of water,lol i cant even leave my apt complex.atleast the power and internetz still works otherwise id be going mad right about now
Old Apr 17, 2007 | 11:09 AM
noahTHEpurdy's Avatar
Car: 1992 Pontiac Firebird
Engine: 3.1
Axle/Gears: 3.42 Auburn Posi
Any pics of the billet strut mounts? How much for them?
Old Apr 20, 2007 | 03:51 PM
Car: 1986 Firebird
Engine: 2.8
Axle/Gears: 3.42s
Hey Dave you still need a boat to travel around? lol
Old Apr 21, 2007 | 01:56 AM
xiholdtruex's Avatar
Car: 88 prelude si/91 camaro rs
Engine: 2.0/3.1
Transmission: D2J5/700r4
if transamrob86 does not get the turbo piping i would be interested.
Old Apr 21, 2007 | 02:25 PM
nope, the intercooler wont fit the front of a firebird, if u like i can get one that will fit and modify the pipes for u, though it will cost slightly more.let me know and ill get ya a price.
alright xihold ill let ya know what happens
ps btw i should have the pipes and all off the car by next weekend
Old Apr 21, 2007 | 03:01 PM
Car: 1986 Firebird
Engine: 2.8
Axle/Gears: 3.42s
Yeah let me know about a price. I have this next week of school then finals week then il be home on tuesday. So it will be tues may 8 before i can get the money and all.
Old Apr 24, 2007 | 07:08 PM
Car: 1986 Firebird
Engine: 2.8
Axle/Gears: 3.42s
Hey Dave I was thinking. Since my car has the battery on the drivers side how much trouble would it be to modify the pipes so I wouldnt have to relocate the battery? I didnt know if it would be more trouble than what you would go thru to fit the new intercooler
Old Apr 24, 2007 | 07:27 PM
1988CamaroSC's Avatar
Car: 92 Camaro RS
Engine: 5.0L
Transmission: AUTO, 56k orig
pics of the seats please
Old Apr 24, 2007 | 08:08 PM
sorry guys i sold the entire car as it sat,see my new post
LT1Formula
20
Nov 14, 2015 12:02 AM
Thomas
Oct 3, 2015 05:34 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
