How to pull an intermidate code
Old Apr 22, 2007 | 11:42 PM
pletch's Avatar
Car: 86Camaro RS
Engine: 2.8L V6
I was hoping some gurus could help me. My CEL keeps turning on and off, i was wondering if that gets stored in the memory if not is there a way to pull the code then since i cant do it while I'm driving and it wont do it at idol?
Thanks in Advance.
Old Apr 23, 2007 | 12:03 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: How to pull an intermidate code
Read the FAQ on this website:
https://www.thirdgen.org/service-eng...ht-error-codes
Old Apr 24, 2007 | 03:24 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Hm. That FAQ link didn't display the connector properly in my browser- it made it look like one long single-row connector.
Yes, an intermittant code gets stored in the computer's memory. It will get erased from memory after a certain number of start/run cycles (if I recall correctly). So you don't have to pull over right away, but don't wait weeks to check on it, either!
Old Apr 24, 2007 | 10:52 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
The code erases itself after 80 good warmup cycles with no problems. So you're looking about 20-40 days it's stored in memory...unless of course you pull the battery or something to clear the ECM.
Old Apr 25, 2007 | 08:36 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Is it just that it warms up or does it have to go closed loop?
Old Apr 25, 2007 | 09:34 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
IIRC, GM says that a warmup cycle consists of starting at or below 80 degrees F. and an increase of 50 degrees or more.
chazman
Aug 28, 2018 03:25 PM
86IROC112
Aug 31, 2015 07:00 AM
chazman
Aug 22, 2015 02:01 PM
GouldyGTR
Aug 21, 2015 10:43 PM
