will installing a cam and injectors from a 3.4 into my 2.8 give me any more power or torque ?
it wont do anything except make u run rich
what about the cam or is that worthless as well ?
if you really want a cam in your car, call delta cams and have them make you one for $45. thats pretty much the easiest way.
Quote:
honestly i dont think the 2.8 in my camaro is worth the cost of an oil change im just wondering sense i could get those parts for freeOriginally Posted by pairtoe87
if you really want a cam in your car, call delta cams and have them make you one for $45. thats pretty much the easiest way. Supreme Member
Quote:
You got yours for $45?!?!?Originally Posted by pairtoe87
if you really want a cam in your car, call delta cams and have them make you one for $45. thats pretty much the easiest way. I paid $100 (with lifters) delivered for a mild turbo grind.
the 3.4 cam is the same cam u currently have in the car
Quote:
Doesn't the 3.4 cam have a timing index on it for DIS?Originally Posted by daves12secV6
the 3.4 cam is the same cam u currently have in the car Senior Member
well yeah the cam was $45 and lifters another $45 IIRC.
Quote:
I remember the lifters being $40. They didn't make me ruturn a core either, said they waived the charge since I lived so far from them and would cost more to mail it then it was worth (the core).Originally Posted by pairtoe87
