Dirty Fuel Filter?
Old May 5, 2007 | 08:59 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Transmission: Automatic
Dirty Fuel Filter?
Ok well my problem seems to be gradually getting worse. When to try to get going after a stop, i have to hit the gas harder than before for it to go. then sometimes with the same amount of pressure on the gas , the tach will increase from lets say 2 thousand rpms up to 25 hundred. Is this a sign of a dirty filter? if so is it hard to change? i know some filters you have to flare lines for.
Old May 5, 2007 | 09:12 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: Dirty Fuel Filter?
Filters are very easy to replace, it takes like 5 min. No flares, just take off the bracket and loosen the two nuts on the fuel line.
Old May 5, 2007 | 10:25 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
ok thanks. does this sound like a dirty filter?
Old May 6, 2007 | 12:16 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
not really, but it does sound like a clogged cat or other exhaust restriction. If you havn't changed the filter recently though, you might want to do it anyway.
Old May 6, 2007 | 12:24 AM
brad_26's Avatar
Car: 1984 camaro
Engine: 2.8l to 383 stroker
Transmission: t5 to th400
Axle/Gears: 12 bolt soon with 3.73s
if its a clogged cat it will rattle alot,loss of power from stop and will have a abnormal exhaust sound
Old May 6, 2007 | 12:27 AM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
not all the time. If it melts on itself, then it might not rattle around, just be a restriction. I've had to cut out plenty that have melted but not made noise.
Old May 6, 2007 | 09:57 AM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
I know its not the cat, because its punched out. How do i relieve the pressure in the fuel system before i disconnect the filter?
Old May 6, 2007 | 10:23 AM
pairtoe's Avatar
take off the gas cap
Old May 6, 2007 | 11:01 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
where is the fuel filter? and what brand should one go with?
Old May 6, 2007 | 11:09 AM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Fuel filter would cause it to stall at idle. Word of warning, DON'T break the line from the filter to the tank, it's 88$ from GM. And it sucks to change.
Old May 6, 2007 | 11:36 AM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
I believe that the filter is on the driver side underneath the rear seat. To relieve the pressure just pull the fuse for the fuel pump and let the car run until it dies. Or you could be like be and just unhook the gas lines at the fuel filter and just let the gas drain.
Old May 6, 2007 | 12:30 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Yes, the filter is in front of the driver side rear tire.
Old May 6, 2007 | 03:42 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Thats exactly what i did. i just got some rubber fuel line and spliced it in. seems to be holding up.
Old May 6, 2007 | 04:46 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Even if you pull the fuse and let the pressure off, there will still be a large amount of fuel in the lines. Pulling the fuse and running the engine relieves excess pressure to prevent it from spraying when loosened. It won't completely burn everything off in the lines.
Old Jun 10, 2007 | 04:28 PM
rover420's Avatar
Car: 88 camaro
Engine: 3.4
Transmission: t-5
Axle/Gears: limited slip posi 3.42
there's a relieve valve on the back of the rail by ur distributer just take the cap off and relieve the pressure easy as that
Old Jun 10, 2007 | 07:52 PM
AdmAnt13's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1 V6 soon to be gone
Transmission: 700r4 Automatic soon to be a T56
I just changed mine yesterday. Pulled the fuse..turnedthe car on and let it stall. Gas still came out and got all over my me but not alot. Easy to change though.
Old Jun 12, 2007 | 07:04 PM
mattydipps's Avatar
Car: 1991 firebird
Engine: 3.1l
Transmission: 700r4 ?
Axle/Gears: stock 343s?
i just had sort of problem with my car after changing half the electrical and countless hours of trial and error i realized one of my injectors were bad
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
