36 MPG, good or bad?
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
I got 540 KM to a tank of gas, 59 Litre tank, with some conversions and fun stuff it was roughly 36 MPG. Is this normal for a 3rd gen?
Re: 36 MPG, good or bad?
Um.
Did you put a hybrid engine in it?
Sounds nearly impossible to me. Are you sure all the math and numbers were right? I'm horrible with math so I wont even try.
Did you put a hybrid engine in it?Sounds nearly impossible to me. Are you sure all the math and numbers were right? I'm horrible with math so I wont even try.
Engine: 2004 LQ4
hmm.. thats a possibility, I've had 2 hours sleep in 3 days so I'm kinda worn out.. But I found out what I did wrong, I typed the wrong numbers into the windows calc. It was 400 KM on the odometer when I filled it up again, that was almost empty. so 400/59 comes out to 6KM per litre..
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
So what is the American conversion. I could believe 26 but 36 is rediculously good.
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
I got 35mpg on time on a trip from L.A. to Phoenix.
26mpg on the freeway is considered excellent for our cars, 20mpg in the city.
Engine: 2004 LQ4
it's probably 20-26 than. Thats with beating the **** out of it all night, too..
Car: 92 Chevrolet Camaro RS
Engine: 3.1L V6
w/ my healthy V6 camaro (T-5), i get 30mpg on highway and about 23-25 in city, if i'm nice to her
, if i'm mean my mileage goes down the **** hole
, if i'm mean my mileage goes down the **** hole Last edited by KBcobra; May 7, 2007 at 04:37 PM.
Car: 87 TA
I get 30-35 mpg highway with my car...29ish in city. the 2.8l in my camaro only got about 12-15 in city. and the 3.1l in my bird got 15-20ish...
Car: 88 Formula, 04 CTS-V, 06 Commander
Engine: 305 TBI, LS6, 4.7 V-8
Transmission: 5 spd, B&M Short Throw
KM to Miles: 0.621371192
Litres to gallons: 0.264172051
Therefore: 400km = 248.55mi and 59 litres = 15.57 gallons
Looks like if your numbers are correct, you achieved 15.96 MPG. If your original 540km for the tank is correct then you achieved 21.55 MPG.
Hope that helps.
I can squeeze out 210 miles per tank in my 3.1 if Im lucky
. Will be fixing that next....at 3.60 a gal, cmon!
Kevman Looks like your getting good numbers though.
Car: Blue 89' RS
Engine: 5.7L
i get 350 miles per tank on the highway in my 89' ... dunno about the 83', never really tested it, but roughly 4-5 hours of drive time.
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
I once got 270 miles on half a tank from here to North Carolina; I still can't believe it myself, but the sending unit and my math are all right.
Car: 87 TA
I usually see 275 miles with mixed driving. I have never taken my car on a trip, I'll put the miles on the Ford or Lincoln first, lol.
Car: 87 TA
yup, 29 in city. being a manual it really helps with gas milage. and the holley street dominator is an amazing carb. it's a big help with fuel economy.
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
my 2.8 gets 0 city...0 highway...lol
Hasnt been in the car for nearly a year!
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
nowadays, anything above 20mpg is good.. 36 is awesome.. what do you do?? run it up to 100mph, cut the engine and roll for 10 miles?? jeez..
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Originally Posted by firstfirebird
The first half, maybe. The first half of a tank will get better mileage than the secon half (not really, but the guage is not linnear).
Car: 89 f-bird and some others
Engine: 3.4
I was getting 28 avg to 33 freeway with my 2.8. 360-380 miles between fillups.
The 3.4 has been sucking down gas (22 ish) I was barely able to go 300 between fillups.
I managed to get up to 24mpg lately after advancing the base timing to 10ish, replacing some vac lines, and getting it aligned.
I don't know how many miles though per tank, as I can't bring myself to drive that long without buying gas because I gotta keep getting it before the next price increase every 4 days.
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I get just a tad over 200 miles on a full tank if I stay strickly on the highway (and under 100mph).
a little over 150miles in the city when I am hot ******* the car.
I really need to get an LSX/T56 setup with gas at $3/gallon.
EDIT: why do I keep posting in the V6 forum?
I get about 16 MPG in the city and about 22 on the HWY. My mileage really depends on my driving behaviour. Sometimes I get 13 MPG in the city (having fun) and other times I can get up to 18 MPG in the city with good driving manners.
Pat
Pat
