Dieing Fuel Pump?
Old May 9, 2007 | 09:13 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Transmission: Automatic
Dieing Fuel Pump?
Today i started my car up, engine was making a noise, so i barely reved it up , noise went a way. Now i can hear a hissing sound coming from the other side of my rear wheels. My buddy said that its my fuel pump going bad. what you think?
Old May 10, 2007 | 05:11 PM
pairtoe's Avatar
Re: Dieing Fuel Pump?
need a little more info to help you out man, but i dont think you can just sya you have a bad fuel pump like that right away.
Old May 10, 2007 | 09:07 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
well today on the way home from school it had no power i floored it and it actually didnt do anything. then sometimes when im going down the road with a steady pressure on the gas pedal the tach shoots up 500 rpms and for some reason the motor seems louder than ever. 1992 3.1 v6 automatic. i just changed the fuel filter but i may have slightly caved a line in..just barely though and it ran fine for a few days after.
Old May 10, 2007 | 09:58 PM
vortecRS's Avatar
Car: 87 RS with a 4.3 votec
Engine: a cammed 1996 4.3 vortec
Transmission: currently TH700R4
Axle/Gears: stock with 3.43s
mine dose that to but tis been doing it for a wial and its a new pump mine dose it mostly on right hand turns wit ha 1/4 tank its a loud huming voice
Old May 10, 2007 | 10:16 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Sounds more like a fuel delivery/engine control problem than a fuel supply problem.
Old May 11, 2007 | 02:22 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
what should i check?
Old May 11, 2007 | 03:53 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Get a fuel pressure gague and check your pressure. Also put a can of seafoam through your fuel system and vaccum system to clean out anything that may be causing your issues.
Old May 11, 2007 | 09:00 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
OK i know this is gonna sound dumb. but i havent learned how to use one yet in school. how do i go about checking it?
Old May 11, 2007 | 09:25 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
If you are talking about the fuel pressure gague then there is a cap (looks like a valve stem cap) that is on the part of the fuel rail where the fuel lines connect. It is right behind the UIM and you should be able to get to it. I have never used one but you get a fuel pressure gague and take that cap off then attach the gague and see where the pressure when the pump primes and when the motor is running.
92camaroJoe
Jul 29, 2023 07:57 PM
jklein337
Sep 19, 2018 06:23 PM
mustangman65_79
Apr 14, 2017 05:37 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
