Cooling Fan Help
Old May 19, 2007 | 05:29 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Transmission: Automatic
Cooling Fan Help
The fan doesnt come on with the A/C and doesnt come on at proper temp. I know the fuse is good but thats it. What should i check next?
Old May 20, 2007 | 12:31 PM
rsrsrs's Avatar
Car: 90 Camaro RS
Engine: 2.8L v6
Transmission: 700
Re: Cooling Fan Help
With my 2.8 the fan didn't kick on at all. So I replaced this sensor on the intake, below the throttle body, and the relay that is attached to the firewall. Now it comes on. One thing I don't like is that it kicks on around 220 which I absolutely hate.
Old May 20, 2007 | 12:51 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by rsrsrs
One thing I don't like is that it kicks on around 220 which I absolutely hate....
Consider going with an aftermarket kit/sensor that allows the fans to kick on at a much lower temperature. Many companies offer them....
Old May 20, 2007 | 05:59 PM
rsrsrs's Avatar
Car: 90 Camaro RS
Engine: 2.8L v6
Transmission: 700
Cool deal, I'll look around. I read somewhere on the site where a person got what your talking about from JEG's.
Is there a way to possibly change the computer settings to kick it on at a lower temp?
Old May 24, 2007 | 07:43 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
No. The temp sensor in the block senses coolant temps and closes the circuit at 220*, causing the fan to come on. Too bad they don't make sensors that close the circuit at like 200*.
Old May 24, 2007 | 11:22 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Axle/Gears: n/a
if it does not come on with the air conditioning i would suspect the relay. th erelay is located ont he firewall relay bracket above the brake booster. it will be the only one with a green wire with a white stripe going to it. ground that wire. did the fan come on? if not replace the relay, if so replace BOTH the ac pressure switch and the block temp switch, or find the broken spot in that wire.
if the fan did not come on replace the relay. then re-check. if it still does not come on hotwire the fan directly to the battery to make sure your motor works.
Old May 24, 2007 | 11:23 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Anyone know which kits work with our cars to make the fans turn on sooner?
Old May 25, 2007 | 10:07 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
If you are still using the '90 ECM, then Yes, it can be changed to turn the fans on & off at whatever temperature you like. Can change a bunch of other stuff too.
RBob.
Old May 25, 2007 | 11:33 AM
daves12secV6's Avatar
u can buy a jet fan switch,or for about 6-10$'s in parts u can make an override switch, wich will allow u to turn the fan on any time u like
alls u need is one toggle switch,and about 4-5 ft of wire.
mount the toggle in the dash, ground one of the 2 pins on the back of the switch. the other pin u run upto the green/white wire on the fan relay.
when u flip the toggle u complete the ground circut to the relay powering up the fan.
the best part is if u forget to turn toggle switch on, the ecm/sensor will still kick the fan on @ 220.
Old May 29, 2007 | 09:40 AM
xbcrguy182x's Avatar
My relay has 2 of those wires going into one contact. Is that normal? Im having similiar problems with my fan. If i ground the green wires to the red, the fan kicks on.
Old May 29, 2007 | 02:14 PM
Xophertony's Avatar
Axle/Gears: n/a
yes, two wires is normal. one comes from your fan switch in the cylinder head, the other comes from your AC pressure switch.
DO NOT connect wires to other wires like that. when we say "ground" the wire we mean to the ground terminal on the battery or to the cars body somewhere. you can screw stuff up just plugging wires into one another if you don't know what you are doing. use caution.
i would replace your fan switch, that will probably fix the problem. if you have a napa near you you can replace it with a lower temperature one. just ask for part number OP6675. fan on at 200-220 off at ~190. the stock one is on at ~240 off at ~220. this is what i use, i do not currently have a toggle hooked up, but i am thinking about getting one. i am probably going to use an extra fog light switch i have laying around. then i can make it so the light lights when the fan is on as well.
Old May 29, 2007 | 02:42 PM
Ahh thanks for the heads up. One more thing, does that mean i can install a manual switch between the green wires and a ground? Would it work? Thanks.
Old May 29, 2007 | 03:21 PM
Xophertony's Avatar
Axle/Gears: n/a
yeah, just splice in to one of the green/white wires and run that to one switch contact, and run the other contact to a ground and you are good.
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
