AC question
Old May 21, 2007 | 11:19 AM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
AC question
I fixed my AC finally just as it is beginning to get hot here in Florida. My question is what type of freon did our cars come with? The old or new stuff? I would like to know for a price if I have to convert it or not and to tell the shop what I would have in my sysem. My car is a 89 RS Camaro with a 2.8.
Old May 21, 2007 | 11:53 AM
forkvoid's Avatar
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
Re: AC question
R12, the old stuff. I'd just convert to R134a; any parts store sells a conversion kit for real cheap. Have a look at this guide: https://www.thirdgen.org/retrofitac
Old May 21, 2007 | 05:20 PM
firstfirebird's Avatar
Re: AC question
I haven't had any luck with those kits.
2.8, you can use freeze12. It's a "safer R12" and if you know a local mechanic, you should get off cheap (it costs them about $20/can).
It works killer .
Old May 21, 2007 | 07:35 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Re: AC question
It works killer .
Can this stuff be purchased from Autozone or another store. I really don't know any mechanics. For me to put freon into my system one place quoted me at about $110 to fill the whole system up.
Old May 21, 2007 | 07:40 PM
Re: AC question
$110 maybe if it is empty, most places will charge you about $40 to $60 a can (some try to charge you this per pound). Too bad you couldn't take a ride down here, I could hook you up. My bud also has the dye to put in it and use a black light after a few days. Then the leak can be detected/repaired properly.
Old May 21, 2007 | 07:46 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Re: AC question
I had to replace the condenser because a rock went through it while on the interstate . There is alot of construction around here for the past couple of years and ahead. I really don't want to pay that much to get freon. I have other things to fix/need. Everything was working great when I got the car back in August. The condenser has been broke since about late Sept. I am just worried that other parts have gone bad.
Old May 21, 2007 | 08:01 PM
Re: AC question
You live in FL, we are always under construction, lmao.
If they would just smarten up and build two lanes at a time instead of one, we would be having some free-flowing highways.
Keep looking around, I made friends with a shop by saving him $3000 on his new roof after the hurricanes two years ago . Actually he always hooked me up even before that, you have to network. Even if it means volunteering some of your time, like I did several years ago and walked away with some good stuff that people left at the shop after a repair (the best was a 2 bolt main '74 Vette motor, but I got rims, heads, even whole parts cars that were salvaged for a major repair).
Old May 21, 2007 | 08:15 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Re: AC question
I am starting to make some friends that are mechanics and have other connections. A guy here locally is replacing my U-joints, trans mount, tailshaft gasket and the gasket on my rear diff where the DS connects for like $80.
Old May 21, 2007 | 08:21 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Re: AC question
Here is the link to the company that sells it--------> LINK.
Old May 21, 2007 | 08:22 PM
Re: AC question
Cool .
Old May 21, 2007 | 08:35 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Re: AC question
Thanks. This will save me a bit of money.
I guess that I would only need this?:
http://www.freeze12.com/miva/merchan...&Category_Code=
Old May 21, 2007 | 09:46 PM
Re: AC question
http://www.freeze12.com/miva/merchan...Category_Code=
Yep, it's cheaper than I thought. Then you just need to buy cans and hang on to the guages.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
