i need help
Old May 21, 2007 | 02:24 PM
92V6camrs's Avatar
i need help
ok well i have yet another problem with my camaro. there is a clicking noise coming from under the air intake manifold. i looked and i seem to have a leak in the fuel lines thats easy but could that be the clicking noise?
Old May 21, 2007 | 04:08 PM
1988CamaroSC's Avatar
Car: 92 Camaro RS
Engine: 5.0L
Transmission: AUTO, 56k orig
Re: i need help
are you sure its not an exhaust leak or even a valve tick?
Old May 21, 2007 | 04:21 PM
rsrsrs's Avatar
Car: 90 Camaro RS
Engine: 2.8L v6
Transmission: 700
Re: i need help
I doubt a fuel leak would cause a ticking sound.
Old May 21, 2007 | 04:40 PM
Car: 92 Camaro RS
Engine: 5.0L
Re: i need help
if it did, and my fuel was leaking, id say f***** run!
Old May 21, 2007 | 04:42 PM
pairtoe's Avatar
Re: i need help
yeah its most likely a valve tick like a lifter or rocker, but you should def fix the gas leak, that can be pretty dangerous.
Old May 22, 2007 | 02:22 PM
92V6camrs's Avatar
Re: i need help
yeah i didn't think it would be but i was a little unsure thanks yall
Old May 22, 2007 | 03:52 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: i need help
Originally Posted by 92V6camrs
there is a clicking noise coming from under the air intake manifold....
Fuel injectors themselves tend to "click" pretty loudly. If your injected, that is.....
Old May 23, 2007 | 03:26 PM
92V6camrs's Avatar
Re: i need help
is there a way i could test each of the injectors to find the problem one without replacing them all?
Old May 23, 2007 | 05:24 PM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
Re: i need help
i second that question.
Old May 25, 2007 | 02:25 PM
micali's Avatar
Car: 1988 sport coupe
Engine: 2.8
Transmission: 700 r4
Re: i need help
I would say check with a speed shop or a engine rebuilder. My local guy can clean them and tell me if I have a bad one. JUst a thought.
Old May 26, 2007 | 09:32 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: i need help
If you happen to have a DMM handy, you can do a test in about 30 seconds to see if the injectors are electrically sound, but I have to ask, what makes you think one or more is bad? Injectors tend to make a clicking noise. That's how they work. Same as the solenoid on top of the starter. If the motor is bad and you try to crank the car, all the starter does is make that loud "CLICK", right? Same with the fuel injectors, except their guts are a lot smaller and don't make as much noise.
Anyways, if you insist on doing the test anyways, here's what you do. Unless you have the newer style one piece connector that only connects at one end of the engine, which I have no idea about, you can do it pretty easily. First off, you have to disconnect the four-wire connector at BOTH ends of the injector harness (you DON'T even want to FRY THE ECM, now) and put the test leads between the first and third, and the second and last terminals. Since we have three injectors at 12 ohms each, you should read 4 ohms per bank (injectors are in parallel, three 12-ohm units in parallel gives a total of 4 ohms). Any more and you have a problem injector and need to go to the next step. Next, if you feel like running a test on each individual injector, you need to push the silver clip IN towards the injector and pull the connector off. Then, using your DMM, probe the terminals and find the injector should read 12 ohms, with about +/- .5 ohm tolerance, and I believe, no more than one ohm diff per bank.
:edit: If, as per your username, you have a 92, you have a 3.1, which has the unitized connector. I would suggest the individual test.
