V6 camshaft???..
Old May 26, 2007 | 11:10 PM
jstrdn90rs's Avatar
Car: 90 RS/90 Z-71/73 Vega
Engine: 3.1/5.7 TBI/5.7
Transmission: 700R4/700R4/350turbo
Axle/Gears: 3.23/3.42/3.42
V6 camshaft???..
Hello all...I was searching for some past threads in hoping someone had posted some opinions on the different V6 cams likes/dislikes.reason I ask is I am getting ready to install some ported heads on my slightly stock 3.1 and really havent decided on the cam yet.I was looking for something that has a slight or noticeable idle..but not irratic.The car is used daily back and forth to work mainly.I was considering the comps 260 cam,mtc-5,or the edelbrock 3790.I understand that some cams arent computer friendly...what can I expect from these non-computer cam?.does that mean I will have problems with the computer function?..And will these cams handle stock valve springs?..someone told me to have the valve pockets enlarged to install stock v8 springs,to handle the extra lift/seat press? Shoot me some thoughts...
Old May 27, 2007 | 12:10 AM
firstfirebird's Avatar
Re: V6 camshaft???..
I didn't spend the money on a name brand cam, Delta Camshafts does regrinds for short money. I got the 260h copy from Delta for $100 including lifters. Just the cam was $55 IIRC. A new cam from them just over $100.
Old May 27, 2007 | 12:20 AM
jstrdn90rs's Avatar
That sounds good...what does the idle sound like?..is it noticeable idle or is it smooth?.How do you like the performance?
Old May 27, 2007 | 10:00 AM
I never got to install it before I spun a rod bearing, now it's getting traded for a manifold . I am trying to work out a deal on a 3.4, so I'm no longer going to need it.
If you do a search, Daves12secv6 has posted sound clips of a similar cam.
Old May 27, 2007 | 11:36 AM
pairtoe's Avatar
yes A+ on delta i have the same cam as them two. its sounds awesome, its loopy as hell on my car until it gets some gas, then it flatens right out. as for performance i have completley tested that out yet, but i will tell you its a big diffrence compared to stock.
Old May 27, 2007 | 12:58 PM
daves12secV6's Avatar
those soundclips were with a much larger cam then the 260
the 260 is a great cam
the mtc5 isnt actually as big as u think it is since they measure duration @001 or something instead of duration @050.
lunati also makes some nice cams
but for the price u cant beat the delta 260 regrind
hey man how that thing running now?
Last edited by daves12secV6; May 27, 2007 at 12:59 PM. Reason: Automerged Doublepost
Old May 27, 2007 | 04:54 PM
I was on the understanding you could go much bigger than the 260 without computer tuning?
Old May 27, 2007 | 05:10 PM
one of my friends was bure chips for me at that time, not that they really helped anyway.the only thing that really made it a lil easier is it was a maf car.
maf cars arent affected as bad by a low vacum at idle, unlike a sd car
Old May 27, 2007 | 06:20 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
Do you by chance have a link to those clips dave?
Here is mine:
http://www.fquick.com/cooltc2004
(Sound clips at the side)
The popping is from my exhaust leak.
Old May 27, 2007 | 06:27 PM
http://2wai.ics-il.com/2.8.flowmaster.idle.wav
the clip is pretty crappy alls i had at that time was a cellphone to record the sound with.i had a better clip but its not on my webserver, ill have to bootup my old comp and see if its on there
Old May 27, 2007 | 08:34 PM
I thought you also had a clip with the turbo cam?
Old May 27, 2007 | 11:21 PM
jstrdn90rs's Avatar
Since we're on the subject does anybody have/know the specs for the stock 2.8/3.1 camshaft??...
Cooltc ...what cam is in your bird in your sound clip?.
Old May 31, 2007 | 07:19 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
I have no idea actually. I bought the motor from a yard when my old 3.1 blew.
Old May 31, 2007 | 08:46 PM
jstrdn90rs's Avatar
cooltc2004,That sounds pretty radical...Since I'm leaning towards the MTC-5 I know some have/had this cam in their v6 ,can you guys tell me if it sounds like it has a cam or does it idle smooth? I have noticed that Summit lists the cam itself having a 110 lobe sep. and the kit with lifters has a 107 lobe sep..The 110 is computer friendly while the 107 isnt,but their both a MTC-5?..I am confused.What is the specs for this cam?.anybody
Old May 31, 2007 | 09:10 PM
The 260 specs are listed in one of my past threads,
https://www.thirdgen.org/forums/v6/4...elp-turbo.html
You guys need to
Old May 31, 2007 | 09:55 PM
jstrdn90rs's Avatar
You guys need to
Okay firstfirebird...I think with that reply I am offically braindead.Now dont get upset at me,I am trying to understand something.is the 260h a delta part number or are you comparing it to the comps cam 260H or MTC-5?,cause if you are the 260H comps is a single pattern cam where as your specs are a dual pattern cam?..and your duration is nowhere near a 260?.
Old May 31, 2007 | 10:22 PM
This is mild turbo grind that is similar to the 260h. The exhaust closes a little earlier to help boost.
260 is advertised duration .
Old May 31, 2007 | 10:44 PM
jstrdn90rs's Avatar
Okay since you cleared that up...I see the Lobe Sep. is about 112 how is the idle like on this cam?..and I am assuming no computer mods necessary with this cam too?..
Old Jun 1, 2007 | 07:11 AM
This is about as big as you can get out of a regrind, and no computer mods needed. Pairtoe will tell you it idles nice with some lop.
Old Jun 1, 2007 | 10:33 AM
the mtc -5 is barley more then a stock cam if a remeber right
Old Jun 1, 2007 | 12:32 PM
pairtoe's Avatar
yeah i really like the idle on this cam. its sounds awesome and levels out once you touch the gas. it has some lop, mine sounds like a pro stock car with the open headers but if you car is basically stock it will sound nice.
Old Jun 1, 2007 | 02:37 PM
noahTHEpurdy's Avatar
Car: 1992 Pontiac Firebird
Engine: 3.1
Axle/Gears: 3.42 Auburn Posi
On that regrind, do you send them a stock cam and they modify it, how does Delta do that exactly?
Old Jun 1, 2007 | 04:38 PM
Just like Discount (or other stores), you buy theirs and send back yours.
BUT!!! Delta is good, they waived my core and gave me free shipping (I live far from their warehouse).
Two thumbs up for Delta...
Old Jun 1, 2007 | 05:14 PM
Engine: 3.1
Awesome, thanks.
Old Jun 2, 2007 | 09:58 AM
jstrdn90rs's Avatar
Thanks for clearing that up firstfirebird....I think a lot of people were uneducated on the topic.I can tell you I am sold..will be contacting them soon with my requests.
Bubbajones_ya
Jul 6, 2024 08:32 PM
db057
Apr 28, 2019 07:45 AM
PurelyPMD
May 5, 2016 04:57 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
GTAman
Sep 26, 2015 02:01 PM
