Where is the sending unit?
Old Jun 8, 2007 | 05:38 PM
xbcrguy182x's Avatar
Does anyone know the location of the coolant temp. sending unit on a 2.8 v6? Im installing a aftermarket gauge but I can not find the location. Thanks.
Old Jun 8, 2007 | 06:41 PM
pairtoe's Avatar
Re: Where is the sending unit?
drivers side head, right near the front coner of the valve cover.
Old Jun 8, 2007 | 07:57 PM
You mean the green plug with like 3 wires attached to it? I thought thats the sensor.
Old Jun 8, 2007 | 08:43 PM
pairtoe's Avatar
yeah all you have to do is unscrew the old one and crew in the new aftermarket one.
Old Jun 8, 2007 | 09:30 PM
hmmm but how can the new one send the temperature reading to the ECM if no wires attach to the new one since its mechanical?
Old Jun 9, 2007 | 08:18 AM
pairtoe's Avatar
did you buy an aftermarke gauge? or sending unit. becuase the after marker gauge is just a water temp gauge with a thick wire coming out the back the has a thermometer on the end and screws into the head. so once you hook that up the stock gauge in the guage panel wont work anymore but the new gauge will.
Old Jun 10, 2007 | 09:27 PM
I bought a aftermarket mechanical temp gauge. I dont care about the stock gauge, because there isnt one...lol But, isnt the thing im replacing a sensor that tells the ECM the temperature?
Old Jun 10, 2007 | 09:30 PM
daves12secV6's Avatar
u have to find a new place to install that watertemp quage there should be a spot on the cyl head u can screw it into
Old Jun 10, 2007 | 09:31 PM
How would that look like? Would it be around the valve covers?
Old Jun 10, 2007 | 09:34 PM
look on the sides of the cyl heads there should be plugs screwed into the sides of them somewere
ah thanks, ill look tomorrow
Old Jun 10, 2007 | 09:50 PM
pairtoe's Avatar
yeah there is one on the drives side head at the front right. right below the bottom corner of the valve cover, and another place to put it is in the back of the passanger side head by the coil.
Old Jun 11, 2007 | 05:46 PM
Alright guys, good news and bad news. I found the sending unit, bad news, I cant get to it...There is a black bracket, some steel lines and the AC compressor in my way. Can I remove this black bracket? How about the AC compressors? Any other tips? Thanks. Here are some pics...
Attached Thumbnails Where is the sending unit?-06-11-07_1826.jpg   Where is the sending unit?-06-11-07_1827.jpg
Old Jun 12, 2007 | 12:55 AM
rover420's Avatar
Car: 88 camaro
Engine: 3.4
Transmission: t-5
Axle/Gears: limited slip posi 3.42
ya man it can all come off just don't unhook ur A/C lines or u'll have to get it recharged. I'd just hang ur compressor to the side and hope that the coolant switch will come out easy.
Old Jun 12, 2007 | 09:05 AM
Alright, ill give that a try. Should I put anything on the new sending unit threads before screwing it in?
Old Jun 12, 2007 | 03:32 PM
rover420's Avatar
Car: 88 camaro
Engine: 3.4
Transmission: t-5
maybe just some anti seize. I'm not sure tho that's a good question it might not need any sealent tho but i could be wrong
Old Jun 12, 2007 | 08:33 PM
pairtoe's Avatar
ive never used sealant and never had any problems.
Old Jun 16, 2007 | 09:59 PM
Alright guys, this is harder than I thought. That black bracket is attached to the ac compressor and PS pump. I removed the ac compressor to try and get to the sending unit, but still very tight. I can remove the large bracket that holds the compressor and PS pump, but i dont have the patience for that now...lol I rather do the more important things in the car and the temp gauge is really just an accessory for now. I still need to fix that cooling fan that wont kick on...
Old Jun 18, 2007 | 10:27 AM
Blue1989RS's Avatar
Car: 1989 RS
Engine: 3.1L + .060" overbore
Axle/Gears: 4.11, Auburn LSD
Wouldn't it had been better to do this to the fan overtemp switch located on the passenger head on the rear? The coolant temp sensor is used for a lot of things. Including the fans.
Old Jun 18, 2007 | 06:01 PM
I didnt try to get to the temp sensor, i tried to get to the sending unit right in front of the valve cover on the drivers side. It has one green wire connected to it, which fell out. If I did this at the fan switch, what would I do with the fan switch if the probe goes in?
tattmann
Sep 27, 2015 05:20 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
wstephan96
Sep 25, 2015 04:28 PM
6998poncho
Sep 25, 2015 02:56 PM
lanceflame44
Sep 25, 2015 12:28 PM
