coolant smell when ac or heater turned on
Old Jun 12, 2007 | 08:58 PM
AdmAnt13's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1 V6 soon to be gone
Transmission: 700r4 Automatic soon to be a T56
So for a while now when the car is on and I use the heat or ac I smell antifreeze. Its not great smelling as you can imagine and am wondering what the causes could be? Simple coolant leak some where? Car never gets low on coolant from what I can tell.
What do you think?
Old Jun 12, 2007 | 09:57 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Re: coolant smell when ac or heater turned on
Very slim possibility of a leak at the heater hoses out under the hood at the firewall, seeping back into the car, but I'd guess the heater core is starting to leak. Real common after all these years. Couple good how-to posts on here if you search. Not an easy job though.
Old Jun 12, 2007 | 10:05 PM
RookieCamaro's Avatar
Car: 1992 Camaro RS
Transmission: 700-R4
Yeah, check if you have a leak in your passenger seat. If you do, its a heater core.
Old Jun 13, 2007 | 08:57 PM
AdmAnt13's Avatar
thanks guys..ill check.
Old Jun 13, 2007 | 09:11 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
Check the floor up to the firewall on passengers side, should be wet if heater core is leaking.
Old Jun 13, 2007 | 09:21 PM
AdmAnt13's Avatar
should be wet only if the heater was running right? I havent used the heater in a while since its summer time
Old Jun 13, 2007 | 09:32 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
No it does not need to be on. Feel around the passengers side floor up to the firewall and you should find some wet areas.
Old Jun 13, 2007 | 10:52 PM
AdmAnt13's Avatar
ok ill check tomrrow
Old Jun 13, 2007 | 11:40 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
If you find that the carpet and pad are wet, pull up the carpet and treat the area so it does`nt start to rust. Por 15 makes some good products to treat rust if you need them.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
TheExaminer
Aug 26, 2015 04:59 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
wayshegoes
Aug 17, 2015 12:00 PM
