Quick vacuum question
Old Jun 13, 2007 | 08:21 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
While checking my vac hoses I knowticed ont T with only 2 hoses connected. In front of my washer fluid resiviour there is a T with one side going to the vacuum ball and one side wrapping back up behind the manifold. Should there be anything on the other side? I looked but didnt see any more lines areound it.
Old Jun 23, 2007 | 04:10 PM
grimmcs's Avatar
Car: 91 Camaro
Re: Quick vacuum question
I got a picture of what I was talking about. Should there bee a tube off that one side?
Old Jun 23, 2007 | 04:28 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by grimmcs
and one side wrapping back up behind the manifold. Should there be anything on the other side? I looked but didnt see any more lines areound it....
Are you talking about a missing vacuum connection behind the intake manifold, or by the wiper resevoir? Behind the intake manifold, just above the MAP sensor vacuum port on the manifold, you should have a vacuum line T'ed in with the Cruise Control, and the HVAC. Note that these two vacuum lines also share a manifold vacuum port with the brake booster....
Old Jun 23, 2007 | 04:29 PM
This line goes directly to your wipers, it carries wiper fluid....
Old Jun 23, 2007 | 04:41 PM
^ Wait a second, I think I know which line your referring to now (that pic you posted threw me off)....
Check the top of your cruise control plunger....
Old Jun 23, 2007 | 05:14 PM
grimmcs's Avatar
Car: 91 Camaro
Yea the bottom of the connector is covered, but you can see the side that dosent have a hose on it.
I dont have cruise control.
Old Jun 23, 2007 | 05:40 PM
I dont have cruise control....
If your steering column is not equipped with cruise control, then that end get's plugged. On my 3.1 w/5-speed , w/o cruise control, that line goes "underneath" the body (via the opening where the horn is bolted to), and plugged. If your column is equipped with a cruise control setting, someone removed it from the vehicle, but either way, the line will need to be plugged.....
Infested
May 22, 2018 11:56 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
bamaboy0323
Aug 15, 2015 07:20 AM
