3.1 in a 2.8 car
Old Jul 1, 2007 | 10:08 PM
diablo666mew's Avatar
Car: 89 camaro RS convertible
Engine: 305 tbi
3.1 in a 2.8 car
my search is not working first off and i did not want to look throught aww the post i am looking this up for a good friend of mind is ther any other bigger v6 motors that u can put in a 2.8 camaro 5 speed that u can use the 2.8 mounts with little mods thanx
sry i did not mean to put 3.1 in the title
Last edited by diablo666mew; Jul 1, 2007 at 10:09 PM. Reason: Automerged Doublepost
Old Jul 1, 2007 | 11:40 PM
L0tuS's Avatar
Re: 3.1 in a 2.8 car
3.4 probly if u want to stay with the same trans. remeber the 3.1 and 2.8 are the same motor just the 3.1 had a bigger crankshaft
Old Jul 2, 2007 | 12:15 AM
Fuzzystyle's Avatar
would there be a big performance boost from a 2.8 to 3.4 engine?
Old Jul 2, 2007 | 12:43 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
yeah the 3.4 was a bad little engine
would be worth it
the 3.4 was used in montes and Z34's and such
was lots better as far as power goes
have to watch head gaskets and such in them though
as with alot of other engines
commonly fail
put new ones on before sticking the engine in the car
save lots of problems later
good insurance for the engine life
2.8 and 3.1 are one in the same on the outside
just different bore/stroke/crank
externally they are identical, brackets and configuration and all that
good luck
Old Jul 2, 2007 | 07:02 AM
Engine: 305 tbi
would a 3.4 out of a 4 gen camaro work with the 2.8 motor mounts and the 5 speed 2.8 trans?????????
Old Jul 2, 2007 | 07:26 AM
firstfirebird's Avatar
The 3.4 is a bored and stroked 2.8. Yes, a 4th gem motor is your best bet.
That is a 3400, a totally different engine. A FWD motor will not work without major modifications.
Old Jul 2, 2007 | 07:41 AM
Engine: 305 tbi
thanx that helps
Old Jul 2, 2007 | 09:48 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
FF, don't forget that the Lumina and Z34 of the mid '90s had the 3.4 DOHC, which is NOT a 3400.
3.4 from a 4th gen F-body ('93 to '95) would be the easiest swap that uses the same mounts and acessories from the 2.8.
Old Jul 2, 2007 | 11:41 AM
Yeah, I know, but I made sure to say FWD to make it easy to determine what engines would work.
Could the DOHC upper end be adapted to a RWD block, though? I have seen the heads on ebay multiple times for cheap money.
Old Jul 2, 2007 | 12:35 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Not even remotely close to swapping around.
Old Jul 2, 2007 | 12:41 PM
EH, I figured as much, but am very UNfimiliar with the design of the DOHC.
Old Jul 2, 2007 | 02:57 PM
Dale's Avatar
Engine: 350 S-TPI
Thats cool. The block has machined slots for the dohc part, then places for "timing covers" to bolt up to it.
Old Jul 2, 2007 | 11:03 PM
Engine: 305 tbi
I suppose I will nead the ECM and engine harness of the 3.4 right ????
Old Jul 2, 2007 | 11:20 PM
QFT!
I have toyed with the idea of making a 4V/cyl pushrod 660, but the pushrods would be going through teh middle of at least 4 of the intake ports IIRC.
No, you retain your 2.8 electronics when you retain the 2.8 intake and accessories.
Old Jul 3, 2007 | 04:01 AM
Engine: 305 tbi
never thought about useing the intake manifold of of the 2.8 nice i think i will do that on his car but manifold and injectors will work with a 3.4 i did not no that wow
Old Jul 3, 2007 | 08:28 AM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
All you need to swap over are the accessories, intake, fuel rail/injectors, and timing cover and you should be good to go.
Reddeath210
Oct 6, 2015 08:20 AM
kyleb24
Aug 15, 2015 08:24 AM
the_nikfive
Aug 11, 2015 02:46 AM
86Base
Aug 8, 2015 01:34 PM
guy76767
Aug 6, 2015 05:58 PM
