timing chain marks
Old Aug 7, 2007 | 03:18 AM
kurfbird's Avatar
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
timing chain marks
Installed replacment engine and car runs like crap. I swaped timing chain prior to install engine. But I had crank at 12 oclock and cam at 6 oclock # 1 TDC. My manual says it should be 12 oclock crank and 12 oclock cam number 1 tdc is this right?? Also cam gear only ahs one mark looks like a pont with a I
Timing mark changed on distributor after car ran like crap. I pulled distibutor and redroped it in. Again pointed to # 1 on distributor cap.
Just pulled valve cover off old motor and both valves look to be closed with pointed on cam wheel at cam at 6 oclock and crank at 12 oclock
Old Aug 7, 2007 | 11:57 AM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: timing chain marks
Sounds like you are 180 degrees out on timing. Try swapping your wires to correct the problem.
Follow the firing order.
Old Aug 7, 2007 | 05:08 PM
kurfbird's Avatar
I replaced the timing chain and gears. Marks were aligned at 6:00 cam and tweleve oclock crank. TDC number one. Held a peice of tissue over hole when it blew out should be tdc #1 .
marks are at 12 oclock cam and 12:00 crank. DOes this sound right?? If I am 180 out what wires should I swap?? I am leaning towards 1 and 4
Thanks for all the help
Old Aug 7, 2007 | 11:12 PM
KrisW's Avatar
Engine: 2.8/TBI/TPI
Your firing order is 1-2-3-4-5-6
Your passenger side cylinders are 1-3-5 from the radiator first
Your driver's side cylinders are 2-4-6 from the radiator first.
Switch 1-4, 2-5, 3-6
If you are 180 degrees out this will put you close and then you can set the timing to perfection. You can also pull the distributor and re-stab it.
Removing and re-installing the distributor is the best and puts you back to factory spec.
Old Aug 7, 2007 | 11:39 PM
kurfbird's Avatar
Will try that tomorrow. Have to finish up the water pump
Vintageracer
Jan 10, 2020 05:33 PM
MY87LT
Aug 17, 2015 08:43 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
