Will not start
Old Aug 8, 2007 | 10:08 AM
dios_198's Avatar
Will not start
Ok my problem started with a blown head gasket. Replaced both of those built the motor back up. Went to start it and nothing engine turns over and i get a burst of compression from the front of the plenum. I,ve tried putting it at TDC and re dropping the distributer still the same ole thing. any help would be apreciated.
This is a 86 2.8l
Old Aug 8, 2007 | 10:20 AM
kurfbird's Avatar
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
Re: Will not start
Have you checked for spark. Verify that all wires are hooked up correctly.
Old Aug 8, 2007 | 10:21 AM
dios_198's Avatar
Re: Will not start
yes i have spark and all wires are correct
Old Aug 8, 2007 | 11:36 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Re: Will not start
You get air blowing out of the intake? Sounds like valves are open/to tight. Or if you took the timing chain off, you installed it 180 off.
Old Aug 8, 2007 | 12:24 PM
dios_198's Avatar
Re: Will not start
yes air out of the intake. i did not remove the timing chain. i could swear i got the valves right. Found TDC tightened exhaust valves 1 2 3 and intake valves 1 5 6 until lash was removed and gave them another 1 1/2 turns, turned the engine one revolution then tightend the rest as long as i got the valves correct. Passenger side is odds with 1 in the front correct?
Old Aug 8, 2007 | 12:26 PM
kurfbird's Avatar
Re: Will not start
did you crank the engine until your finger. I used paper towel was pushed off for TDC #1
Old Aug 8, 2007 | 12:51 PM
dios_198's Avatar
Re: Will not start
yea i had a friend stick his thumb over the hole until he felt compression after that we tightened down the rods until we could not spin them by hand and gave them another turn and a half
Old Aug 8, 2007 | 01:26 PM
Dale's Avatar
Engine: 350 S-TPI
Re: Will not start
Thats to much. Lash is up/down movement, not spinning (been big debate on this).
Try doing a compression check, I bet you have little/no compression.
Old Aug 8, 2007 | 01:33 PM
dios_198's Avatar
Re: Will not start
you know of any place that will rent a compression tester?
Old Aug 8, 2007 | 03:11 PM
Dale's Avatar
Engine: 350 S-TPI
Re: Will not start
There less then 20 bux from a parts store. There dirt cheap.
Old Aug 8, 2007 | 04:01 PM
dios_198's Avatar
Re: Will not start
oh didnt relize they were that cheap what kinda pressure should i be getting
Old Aug 8, 2007 | 08:05 PM
Dale's Avatar
Engine: 350 S-TPI
Re: Will not start
Uh, it partly depends on CI, compression, and milage on the motor. I dont think I ever got below a 120 when I wasnt having problems? Maybe some others can comment on that part.
Old Aug 10, 2007 | 09:52 AM
dios_198's Avatar
Re: Will not start
Well checked my compression today! You were right had barely any. I'll have it back together later this afternoon and give it another try
Old Aug 10, 2007 | 07:01 PM
dios_198's Avatar
Re: Will not start
Got her all back together and running like a champ. Thank you all for your help.
Old Aug 11, 2007 | 04:25 PM
Dale's Avatar
Engine: 350 S-TPI
Re: Will not start
Did you do a compression check after you were done? Or if you have a vac gauge, throw it on and check.
Old Aug 11, 2007 | 11:07 PM
dios_198's Avatar
Re: Will not start
sure did compression was between 150 to 161
Old Aug 12, 2007 | 09:08 AM
Dale's Avatar
Engine: 350 S-TPI
Re: Will not start
sounds like some good healty numbers.
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
