91 FIREBIRD V6 STARTING BUT NOT IDLING!!!HELP ME!!!
Old Aug 9, 2007 | 01:52 PM
w_mortell's Avatar
Car: 91 Camaro
Engine: 3.1 V6
Transmission: Automatic
Axle/Gears: stock(what could be better!!)
I JUST BOUGHT A REPOED 91 FIREBIRD 3.1 (MAF) 5 SPEED. I GOT NO KEYS WITH THE CAR. AND IT HAS VATS!!!! SO I RAN A SWITCH TO THE FUEL PUMP AND THE STARTER RELAY TO GET IT TO START. BUT I CANNOT KEEP IT RUNNING, IF I PRIME IT WITH GAS INTO THE THROTTLE BODY, I CAN GET IT TO START BUT I HAVE TO TAP THE PEDAL TO KEEP IT RUNNING, IT WONT REV UP, I HAVE REPLACED FUEL PUMP, FILTER, PLUGS AND WIRES, CHECKED MY DIST. CAP(THERE WAS SOME CORROSION ON THE ROTOR, BUT CLEANED IT OFF), I STILL HAVE A FEW MORE THINGS TO CHECK OUT. I AM JUST NOT SURE IF IT IS A FUEL ISSUE OR AN ELECTRICAL ISSUE...ANY INFO ON THIS WOULD JUST F*IN ROCK....ANYBODY!!!!!
Old Aug 9, 2007 | 05:15 PM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
Re: 91 FIREBIRD V6 STARTING BUT NOT IDLING!!!HELP ME!!!
The VATS controls the starter, fuel pump, and the ignition.
You many want to buy a bypass unit.
Old Aug 9, 2007 | 09:09 PM
w_mortell's Avatar
Car: 91 Camaro
Engine: 3.1 V6
any idea where i can get a bypass unit? ebay???????or do you know how to wrig up the ignition? i know what i am doing is the wrong way to do it, but i dont have alot of cash and i need the damn thing to run...
Old Aug 9, 2007 | 10:25 PM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
https://www.thirdgen.org/vats_passkey_system
92firebirdguy
Sep 1, 2016 07:53 AM
86IROC112
Nov 7, 2015 06:50 AM
TexasFormula
Sep 30, 2015 06:36 PM
lanceflame44
Sep 25, 2015 12:28 PM
steimel94
Sep 20, 2015 12:46 PM
