will the breather work?
Old Sep 7, 2007 | 08:00 PM
draco's Avatar
Car: 1992 Camaro RS 25th Anni.
Engine: 5.0l TBI
Transmission: 700R4 Automatic
Axle/Gears: 3.73 Gov lock
I just got my 1991 camaro RS 3.1l v6 fixed from some front end damage. I am installing an 1987 iroc front clip on it. Well included with the front clip was the dual snorkel setup that runs down the nose of the car. Will i be able to use this on my car or will it mess up my computers readings?
Old Sep 7, 2007 | 08:25 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: will the breather work?
as far as i know, you need the air filter box with it too, a few push clips, and remove whats there already, but it will work. may wanna do a search to confirm this though.
Old Sep 7, 2007 | 08:39 PM
draco's Avatar
Engine: 5.0l TBI
Right, Well i have the complete iroc, the rear end is trashed though. So finding the air box and ducting shouldn't be a problem. I searched and found some threads on this. They all say i need an extension pipe, which i understand. What i do not understand is what to do with that sensor that is on my factory intake now?
Old Sep 7, 2007 | 08:47 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
for a 91 that should just be an air temp sensor. Stick it in the nose where your air filter will be just like it was with your air filter on your old setup.
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
db057
Aug 22, 2015 08:17 PM
Fronzizzle
Aug 17, 2015 02:52 PM
