Vented or Sealed gas cap
Old Sep 11, 2007 | 06:24 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Vented or Sealed gas cap, does it really mattter cept to the EPA?
I want one of the caps with a flap in so you can fill up without taking it off.
Old Sep 11, 2007 | 06:29 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Vented or Sealed gas cap
It probably doesn't matter except to the EPA, as long as there's some kind of venting for the tank.
Old Sep 11, 2007 | 11:46 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
In my experience, the ones with the flip top are typically worse to have because they tend to not seal right and leak out the fumes on hot days...resulting in what looks to be poor milage.
about 31% of people who complain of poor milage can attribute their problem to an undermaintained EVAP system, which includes the fuel cap and EVAP hoses. The fuel actually evaporates right out the hole. A hole 0.020" in diameter can cause a lose of aprox. 1 gallon of fuel per month.
In California we're actually going to be testing the evap system of all vehicle between 1976 and 1995 for EVAP problems using a special tester starting on Nov. 1st as part of the smog inspection.
Old Sep 12, 2007 | 10:59 AM
noahTHEpurdy's Avatar
Car: 1992 Pontiac Firebird
Engine: 3.1
Axle/Gears: 3.42 Auburn Posi
That's good to know! I think I'm going to check the rubber lines of my EVAP system, as I think some are dryrotted.
1992 Trans Am
May 10, 2023 07:19 PM
chazman
Aug 28, 2018 03:25 PM
chazman
Aug 22, 2015 02:01 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
