Look at what came in the mail today
Old Oct 1, 2007 | 03:14 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Ported Heads!!!!
Fully ported heads from Pairetoe's engine that he parted out. I also grabbed his cam (copy of the 260H), 1.6 roller rockers, lifters, and pushrods. Now all I need is a motor to put these on.
Old Oct 1, 2007 | 06:51 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: Look at what came in the mail today
Did you get the lifters with that cam, and seperated and numbered so that they go back on the SAME lobes?
Old Oct 1, 2007 | 07:14 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
I got lifters and pushrods too. The parts only had 50 miles on them so I'm not to worried about that.
Old Oct 1, 2007 | 07:43 PM
Looks like a lot more wear than 50 miles. My Cam that had over 20000 Kms had less wear indications than the one you have pictured.
besides, once they are broke in, they HAVE to go back on the same lobes, the entire reason for break in is to set the wear pattern between the cam and the lifters.
Old Oct 1, 2007 | 10:07 PM
pairtoe's Avatar
that cam is brand new. all those parts are. i had them in the car and only put on 50 miles before i parted it out. they sat for a year before they got put in, and about a month after, until now. but happy to see you got every thing. haha i think i even left the spark plugs in the heads.
btw any luck with the victor gaskets?
Old Oct 1, 2007 | 11:59 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Pictures can be decieving when showing camshaft wear. The flash makes it look ALOT worse than it actually is in many cases. That being said, you can reclaim lifters fairly easily and even put new lifters on a used camshaft.
Old Oct 2, 2007 | 12:29 AM
I've had people say that exact same thing to me, as they were installing new lifters on thier "barely used" cam, and usually only a couple months later they do the very same thing, because thier lifters are worn, and then again a few months later, until they listen to me and replace both cam and lifters with new ones at the same time.
I don't doubt that flash can change the way things look, as I have experianced that first hand, but damn, that's a lot of flash flare to look that bad.
Old Oct 2, 2007 | 06:40 AM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
I haven't gotten around to looking for Victor Jr askets yet, I will soon. I have other problems to worry about tight now like my current motor.
I did use the on the camera because my room is a little dark on that side from a blown bulb.
Linson
Oct 24, 2025 02:00 PM
86IROC112
Nov 7, 2015 06:50 AM
bjpotter
Oct 4, 2015 07:48 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
paul_huryk
Oct 1, 2015 04:27 PM
