stalling out
Old Oct 12, 2007 | 04:54 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Axle/Gears: 9 bolt posi 3:27
stalling out
i recently bought an 85 firebird. 2.8 6cyl manual tranny. every once in a while i'll be driving down the road and when the rpms get to about 1k or so the car stalls on me. this is a little annoying and im not sure what it could be. a fuel problem maybe but the person i bought the car from says she had a new filter put on it and pump. she did say the battery was low but im not thinking that this would cause that problem. the car starts right up without any problems after it stalls. any information leading to saolving this problem would be great. thanks
Old Oct 12, 2007 | 06:20 PM
AmorgetRS's Avatar
Re: stalling out
I am moving this to the V-6 section for you, they can probably help you a lot better there.
Thanks,
Douglas
Old Oct 12, 2007 | 06:27 PM
rsrsrs's Avatar
Car: 90 Camaro RS
Engine: 2.8L v6
Transmission: 700
Re: stalling out
Have you done a tune-up?
Old Oct 12, 2007 | 06:48 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Re: stalling out
no tune up done yet. could that be it though? the oil was just changed i know that. but would a normal tune up fix the stalling problem. also they said the egr valve was replaced
Old Oct 13, 2007 | 03:56 AM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Re: stalling out
i think i figured it out! im thinking maybe the idle is too low. and maybe my throttle spring is bad and i need to replace it. or maybe the entire throttle body. any advice on this would be helpful. what is a 2.8 with a manual tranny suppose to idle at does anyone know?
Old Oct 13, 2007 | 09:21 AM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
Re: stalling out
Check Vacuume lines, All normal Tuneup items, check connectors for loose/broken ones.
The idle on these cars is controlled by the ECU via the IAC (Idle Air Control), if you have a vac leak the IAC can not compesate for the air leaking into the system so the car will either Idle high or not at all. If you touch the Idle screw you will just make it worse.
If its stalling when your driving i would also check the coil. mine would die randomly till i changed it, tho once i had replaced it i ran into the clips holding the connection did not want to hold. so i had to replace them cause the would come loose.
Old Oct 13, 2007 | 09:47 AM
Scamo-2.8's Avatar
Car: 1989 Camaro RS
Engine: 1990 - 5.7
Transmission: Tremec 3550
Axle/Gears: 9 Bolt - 3:45
Re: stalling out
I couuld be totally off here but when I had my v6 it had similar problems. The mechanic I took it to said look at this, he tapped the mass air flow sensor (kinda like knocking on a door (with your hand) and the car stumbled and died. So give that a shot. It's an easy way to know if it's good or not.
Old Oct 13, 2007 | 11:28 AM
forkvoid's Avatar
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
Re: stalling out
A good rule of thumb I've always been told: Don't touch the idle setting.
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
lanceflame44
Sep 25, 2015 12:28 PM
amcnellis
Sep 16, 2015 04:16 PM
