How does the Heater/AC Compressor work ?
Old Oct 16, 2007 | 12:40 PM
Mitchell22's Avatar
Ok I got Idle problem on my Firebird 93 V6 3.4L
I found that when my Heater is OFF and AC Off my Compressor's bearing turns the ACC Strap but not the compressor itself. (I can see the front of the compressor isn't turning)
When I open my Heater or AC. The front of the bearing turns too.
Like it should
But SOMETIMES it stop then start again back. When it stops, my RPM drop to 750, when it starts back it jumps to 900.
Isn't that supose to always turn when on?
Old Oct 16, 2007 | 01:14 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: How does the Heater/AC Compressor work ?
The compressor doesn't always run when the a/c's on, there's many conditions set in the ecm to controll when the clutch applies. I.E. below a certain rpm or temp it won't engage.
Old Oct 16, 2007 | 04:32 PM
Mitchell22's Avatar
Yeah learned that D: today...
Anyway still have my RPM Problem.. too bad, thank
TheExaminer
Aug 25, 2015 07:34 PM
rh76camaro
Aug 15, 2015 12:48 PM
Street Lethal
Aug 13, 2015 08:28 PM
Street Lethal
Aug 12, 2015 11:33 AM
Thaney9
Aug 7, 2015 08:25 PM
