newest development
Old Oct 19, 2007 | 12:06 AM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Axle/Gears: 9 bolt posi 3:27
newest development
ok well either my car doesnt like where i park or its scared of the dark. actually i dont know what but i have an idea. the symptoms are during the day it starts fine no problems. at night, im guessing when the temp goes down, it wont start. this is right after i put a full tank of gas in it. so im thinking i got a bad batch of gasoline, my luck indeed. would a fuel treatment like a store bought octane booster solve this dilemma. or does anyone have a better idea of what it could be. its a 85 firebird s/e 2.8 5 speed manual
Old Oct 26, 2007 | 09:00 AM
bifnasty's Avatar
Re: newest development
well assuming that you are getting a good spark, you could try using seafoam in the gas tank, and they have a product called deep creek. it is like wd40 on steroids. it acts like starting fluid/carb cleaner/lubricant. with the seafoam in the tank and spraying down the intake the car should turn. if not let me know.
Old Oct 26, 2007 | 12:18 PM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
does it start at all? Or just crank? do this test -- turn key to run position but don't start it. Is the fuel pump making noise? If not, start there. If it is making noise, check the fuel pressure
morrow
Members Camaros
196
Jan 13, 2024 12:21 PM
Street Lethal
Apr 30, 2019 12:14 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
timonator
Sep 13, 2015 11:49 AM
MSgt Luttrell
Sep 5, 2015 11:28 AM
